Question about Lexmark X73 All-In-One InkJet Printer
Cord Connections I am needing to find the cord that connects the unit to the computer. We bought this printer from someone but they did not supply us with the proper cords.
  • 4,472 Answers
Printers do not come with the USB cords. You can purchase one from any store or any online website here is an example.
http://www.amazon.com/Belkin-F3U133-10-Hi-Speed-Cable-Feet/dp/B00004Z5M1
Thank you,
Lee
Posted on May 23, 2009
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
My xbox has a three light red ring
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
BACK PANEL OF CAR MP3 PLAYER UNDERSTANDING CONNECTIONS. i'VE JUST BOUGHT A CHINA MADE CAR MP3 / FM PLAYER. IT'S BACK SIDE HAS GOT 2 SETS OF SPEAKERS CORDS. ONE BLACK CORD LOOKING LIKE AV CONNECTION JACK...
from what you describe, the red wire is definately power in to the unit ((+) hence the fuseable linkage). Blue is an odd color in electronics, so if its next to the red it is more than likely return voltage ((-) in DC circuits return voltage is grounded. Typically a head unit will have the wire diagram printed on a sticker placed on top or the back of the unit.
AND FOR THE BLACK CORD, thats for then fm antenna, there should be a cord that looks just like that one behind the unit, only the vehicle end is the male end.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 05, 2010 | Car Audio & Video
No power - check all connections
If there's no power at all on the unit , try first connecting it a different power source and if still the same problem try using a different cord this can be a problem with the power cord....
Dec 13, 2009 | Dell 922 All-In-One InkJet Printer
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
My Canon MP780 will not power on.
This is what the service manual says;
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Power cord
You may have a broken solder connection - some sort of broken or intermittent connection. Common problems are broken solder connections at the power jack (inside the laptop). If this is the case, the laptop will need to be disassembled for repairs to be made. Note: There are online sites with DC power jacks available, crossed by Model number.
Wiring can also break (external to the laptop) especially if the wire/cord is flexed frequently (like when wrapped up to put into the laptop bag). Sometimes there is no external evidence of a break.
Also, if indeed your laptop has a pig-tale as you describe, the jack where you connect might be worn out- just not making contact with the plug.
Find someone with a little tech savvy, if necessary, and locate the exact nature of the bad connection, and make repairs from there.
Jul 03, 2008 | Computers & Internet
Toshiba Satellite P105 S6124 Power goes off. Jiggling electrical cord at base of computer gets it back on but when it's moved, it goes off again. Someone looked at it and tried a new cord. Determined...
First, the power cord connects to the Power Unit not the Motherboard, so if jiggling the wire causes the fault, it is either the Power Supply Unit or just the plug and wiring that the power cord plugs into.
If you must open the casing, try replacing the Power Unit, but the best solution is to get a computer repair person to look at it.
If you pull the unit apart and start poking around in there, you will almost certainly blow something up with static electricity (and then maybe your Motherboard will need replacing!). Note The voltage of Static Electricity (which you probably can't feel) is THOUSANDS of times higher than the Voltage that your computer components runs on. For comparison connect up a Mains Supply to a 12 volt globe and see what happens (and this is only 10-20 time higher than the required voltage.
Good luck.
Apr 13, 2008 | Computers & Internet
Lexmark X73 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
