Question about HP Pavilion dv9628nr Notebook
Computer wont turn on
When i plug in my DV9628NR, the light connecting the power cord to the laptop comes on just fine, but the charging light doesn't come on, and the laptop wont turn on, no matter how long i charge it. I didn't know if this might be the battery or another problem, but I thought I'd ask before I went and spent the money on a new one. Thanks.
  • 2 more comments
  • nixonlegionn May 23, 2009
    I have tried to take the battery out and turn the computer on, and it doesn't turn on. I don't own another power cord, but I don't think it would be too difficult to find one. The battery is about a year and a half old, and the computer has been almost constantly on for that period of time. I had no problems with the computer before this.
  • Carlos Soto
    Carlos Soto May 11, 2010
    Since you have already removed the battery, I would rule it out for now. However, you could check on the power supply by using a voltmeter, as suggested by byteguy or check out purchasing a new power adapter in the case that you don't have a voltmeter. I would probably purchase one someplace where if it was not a faulty p/s, I could return (without having a 15% restocking fee). Keep us posted.
  • Carlos Soto
    I would see if I could try and test it with another power cord. When you remove the battery does it come on when it's plugged in? It should if everything else is working OK. If the battery doesn't charge, that would be the battery. Do you have means to test out another cord?
  • Anonymous May 11, 2010
    Did you take the battery out, check it's connectors and reinsert it it? Make sure it is in tight. How old is the battery? Most just last a little over a year or two.
  • 2,229 Answers
You can check the power adapter by using a voltmeter to see how many volts the adapter is putting out. If it's within normal limits (should be about 18 volts if memory serves correctly--although the voltage should be listed on the adapter), then you are looking at a motherboard problem. Even if the battery is no longer able to hold a charge, the computer should still start. Sounds to me like it just quit all of a sudden.
So--first check your voltage.
Then check e-bay for a used motherboard. If you are not inclined to work on a laptop to this extent, you will probably be further ahead to buy a new or reconditioned one.
Let me know if you need further info.
Posted on May 23, 2009
    Guru:
  • 832 Answers
Hi thanks for using fixya!
May I ask, how many years now is your laptop?
Try to remove the battery, and use the AC adapter instead, connect it to your laptop, check if its going to have a power. Turn it on. If its turning on and working normally, then the problem is your battery, you have to purchase compatible and original battery. If its not working while it is connected to the AC adapter, check if the adapter is supplying power, because maybe the problem is with the AC adapter.
If you need further assistance, let me know.
Why wont my lap top come on
Hello there.
There's a chance that it's a problem with the battery. But we do need to run some tests to determine the cause of the problem.
1. Kindly make sure the wall outlet is working by plugging inanother device like a TV or lamp, just to check if power is coming through it just fine. 2. Turn off the laptop completely. Unplug all the cables connected to the laptop, including the power cord then remove the battery. 3. Plug the power cord back to the outlet(without the battery inserted) then press and hold the power button on the laptop for 10 seconds. Then check if it would turn on. If it does then it means the problem is with the battery and it needs to be replaced or you can try to charge the battery again with the laptop turned off.
It would also help if you can give me the complete brand/model of the laptop.
Have a nice day.
Nov 21, 2011 | Toshiba Computers & Internet
No power from my laptop .... cord has power but computer wont power up. No lights coming on computer or anything. Cord has blue light on .
Can you try to remove the battery then plug in the power cord then try to power on the computer, if it still doesn't work, call you manufacturer as you might be having a hardware issue.
The power supply may not be working on this instance.
Jul 10, 2011 | Dell Inspiron 1545 Notebook
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Psp carge light wont come on and psp wont turn on
You either have a bad battery, or a bad power supply that charges the unit (power cord). If you have a friend that also has a PSP, try swapping out the battery to see if that works, and or try another power cord to see if the charging indicator light comes on. I think that possibly your battery is dead and the power cord might be bad. You can find good deals for both the battery and cord on ebay. Good luck!
Nov 07, 2009 | Sony PlayStation Portable (PSP) Console
The little orange light that comes on when the computer is charging just flashes and computer wont trun on what does this mean?
Make sure the power cord is securly connected to the computer and that it plugged in. Are you sure the battery isn't emty?
Try taking out the battery and leave the power cord plugged in and try to turn it on.
Mar 13, 2009 | Acer Aspire 4720 Notebook
Won't turn on
how old is the system
could be your internal plug for ac may have become lose from plugging and unplugging
or you may just need a new ac cord
try moving it around where it plugs into the laptop if you get a brief connection then it probably is the connection inside the laptop they can be replaced
Jan 16, 2009 | Computers & Internet
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Acer Aspire won't start
make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Jul 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
HP Pavilion dv9628nr Notebook Logo
167 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
