Question about Logitech EasyCall Desktop? Keyboard and Mouse
Logitech Easycall Desktop mouse work, but keyboard quit working
I have a logitech Easycall Desktop set (USB speacker, codeless mouse and codeless keyboar). they were worked fine, but suddenly keyboard quit working. I have checked the connection, it looks like connection OK since some featured key like meadia button works, but no alphabetic and numbers keys work. I have reinstalled the software and checked the status, it look normal. I tried reconnect with secure connection, all normal.
yooperbud
  • 8637 Answers
SOURCE: logitech ex 100 mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 22, 2009
myjosh007
  • 530 Answers
SOURCE: easycall desktop and mouse i cant connect mouse.
hi im josh in cebu phils.may i help you friend? if the mouse wont work.there may be some problem on it. first check in the bios setting if the pheripherals mouse is enabled.enable it if not then check wether ps2 or usb is enabled it should be comaptible. try to see also in the my computer device manager if the mouse is present in connections. or try to check the connections in at the back of the cpu try to see if it is not loosen.firmly attached then reboot the pc.after rebooting if it still doesn;t work try to use another mouse if it works then the problem is your mouse try to secure new one. good luck. hope i helped you.
Posted on Feb 26, 2009
SOURCE: logitech easycall mouse works but the keyboard will not
I had the same problem. Some keys on the keyboard would work, others not. It seemed to happen after an update to the SetPoint software. I got it fixed! I tried everything and in the end this is what worked:
1. I started the computer and obviously could not log in.
2. My mouse worked, my standby key worked, but no other keys.
3. I used the mouse to activate the on-board keyboard in Vista (left bottom corner).
4. I put in my password and logged in.
5. I opened up an app (Excel in my case) to try to type something in.
6. As soon as I hit a key a Logitech wizard for encrypted communication came up!!! It asked me to press the connect button and then enter a code it displayed (keyboard worked at this point).
From this point on the keyboard worked!!
Note to Logitech.... great job on the extra security... bad job on the implementation... if your wizard runs after a PC is rebooted that has login passowrd protection.... how are the users supposed to log in??
Note: My logitech upgrade hung... with mouse and keyboard becoming unresponsive so I had to do the hard power off... maybe the wizard was meant to run after the upgrade before I had to force a restart, but this is something that should be taken into account as well.
Posted on Jun 19, 2009
FoxSysTech
  • 23 Answers
SOURCE: My Logitech EX 100 keyboard and mouse combo doesn't work
Make sure the batteries work by testing them in another device(sometimes they lose their charge if they have been in the box too long). If they are charged, make sure you have the devices connected directly to the computers onboard USB port so that you can be sure it is getting enough power to the reciever.
If this does not work, it might be a hardware setting on windows. You will want to make sure all of your drivers are installed properly in device manager, this is unlikly the problem but it has been known to happen. Make sure the mouse and keyboard are aligned properly with the reciever.
If your computer is running slow, it may just take a long time for windows to recognize the new device. If you do not hear windows responding by making the 'new device found' sound then it probably is not detecting the new device in which case it is probably something wrong with windows or the drivers. If it does make the sound and it says it is loading and you see the ballons pop up on the bottom right then it has sucessfully connected.
If all of this does not work, then I would say that they are toast. Try them on a different computer if you can. This should give you a definate idea of if it is a problem with your computer or a problem with the device itself.
Posted on Jul 03, 2009
  • 1738 Answers
SOURCE: mx5500 no connection
Windows 7 firewall program is blocking your program.
Posted on Jan 03, 2010
Will other Logitech mouse work with Logitech EasyCall Desktop?
Hi Warp you can not use any other mouse with your Logitech Easycall Desktop receiver, but with the additionnal mouse's receiver connected you should not meet any conflict using both at the same time. Thanks and have a nice day. Crenshow
Jun 06, 2010 | Logitech MX 600 097855036162
Logitech mouse quit--we have a microsoft wireless laser 8000 mouse--can the loitech wireless keyboard be made to work w/the microsoft mouse
Yes, you can. Bur you need to insert the dongle to USB port which is came along with the Keyboard. Also install the driver for the same.
Dec 15, 2009 | Logitech Wireless Access Duo Optical...
Logitech easycall desktop keyboard mouse combo...mouse connects, keyboard does not after replacing batteries???
Usually there will be a connect button, it sync them up together. First press the one and hold on the receiver then press the one on the keyboard. Sometimes they can be under/ on the bottom of the keyboard.
Sep 09, 2009 | Logitech EasyCall Desktop 967689-0403...
How do I change battery in Logitech cordless mouse
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=c*kceLDj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=3124&p_created=1145546604&p_olh=0
Jul 25, 2009 | Logitech EasyCall Desktop? Keyboard and...
Easycall desktop and mouse i cant connect mouse. keyboared workng ok and no mouse settngs in logitech mouse and keyboard settings
Feb 26, 2009 | Logitech Cordless Mouse
Logitech easycall mouse works but the keyboard will not
Jan 30, 2009 | Logitech EasyCall Desktop Retail Keyboard,...
Wireless Keyboard not connecting
I opened up the Logitech Mouse and Keyboard Settings, turned my keyboard off, changed out the batteries and turned it back on. It then detected the Keyboard and asked for a password, I entered in the password, it said it was rebooting it and asked for another password which I entered (both passwords were given to me in the Settings). Now it is working just fine! Not sure if you have tried this but it might work for you.
Jan 04, 2009 | Logitech EasyCall Desktop? Keyboard and...
I put the USB plug in the two plug housings and the control immage on the screen still says "plug it in". It looks to me that my PC does not recognize my logitech web cam as it did in the past.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 03, 2009 | Logitech EasyCall Desktop Retail Keyboard,...
Keyboard works but the mouse won't work (starlogic wireless optical set)
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Jul 06, 2008 | Logitech EasyCall Desktop 967689-0403...
Weird problem with easy call
If there is a dongle plugged into a USB port, try another port, i have a logitech wireless desktop, and it used to have probs when connected thru a specific USB port, also reinstall the drivers and check batteries.
Mar 31, 2008 | Logitech EasyCall Desktop 967689-0403...
Logitech EasyCall Desktop?  Keyboard and Mouse Logo
157 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
