Question about LG WM2277H Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Hi the Whirlpool Duet, front loader had a DL signal, how can I correct this door lock error? Thank you!
  • Anonymous Mar 26, 2014
    dl error code
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
Sometimes the error of DL shows mean door not locked , the signs of keys must be shown on the screen when it safely locked , all what you may do is ; try 3 more times to turn off electricity completely from the washing machine , then wait 10 seconds and try again , and don't try to push the door hardly just close it , then PUSH the door with your both hand (after closing it ) for 5 seconds , you will then see the display signs locked (key sign) and it will work normally .
Posted on Sep 27, 2014
  • mahabishara Sep 27, 2014
    am sorry , my answer about DE error not DL
  • LG Master
  • 3,361 Answers
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
Posted on May 23, 2009
Dl code
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet GHW9400PWO and it will not turn the water on. When I press the start button I am getting an error dL and then F and it just beeps.
Error DL sound like a door lock problem. The door latch lock assembly is all one part. If door doesn't lock a signal is sent to the main control telling it there is a problem. Thus the error code. Nothing will work till door locks. 3 screws hold the assembly in place, but you have to partially remove door boot to get the door latch out.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It keeps flashing dl-f
Hi here is the meaning of the code and the corrective action needed. If you have any other questions please feel free to comment. Mike
"F/dL" Door Lock Error
  • Door Lock Mechanism broken or removed from the Door
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My door keeps locking and then it wont open. It beeps DL or F11.
Hi There
I have found the codes for you and hope this will help you.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
F/dL Door Lock Error
Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool Washing Machines
Whirlpool washer
F/11
Check Wire Harness connectors to the MCU, the motor, and-
Check MCU
Check CCU
Check Motor
Check Wire Harness
F/dL
Door Lock Error
Check the wire harness connections to the Door Lock/Switch-
Feb 23, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer won't start
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
Control Unit (CCU)
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277H Front Load Washer Logo
313 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
