Question about Dell Inspiron 1525 Laptop
Dell laptop screen goes blank when ac adapter plugged in
I have dell laptop 1520 inspiron, which is purchase on february 2008. When I attache power adapter, screen goes blank and with battery it is working with some screen flickering. please advise how to solve this problem
  • 4 Answers
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
Posted on Jul 24, 2010
    Sergeant:
    Champion:
  • 320 Answers
Have the battery checked
Posted on May 23, 2009
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
Changing battery motherboard
Gciappa,
Dell Support > Inspiron 1520 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1520/en/sm/index.htm
Click on Coin-Cell Battery in the right hand list.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft static free cloth on the table you're working on. Helps prevent scratching the table, and laptop.
Turn the laptop over, Battery Compartment facing away from you.
3) Remove the Memory Compartment Cover,
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/html/about.htm#wp1175774
(Number 2 - memory module/coin-cell battery compartment )
The RTC Battery is that small plastic 'bag', that has a Red and White wire coming out of it, and ending in a small white plug connector.
(Real Time Clock Battery. Term coined now for CMOS Battery )
Replace battery, close cover, reinstall main battery, and AC adapter.
Regards,
joecoolvette
Nov 04, 2012 | Dell Inspiron 1520 Motherboard
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Hi my dell inspiron 1520 not starting when power button is switched on..the power light blinks and goes off..and the system doesnt start. I had shown the laptop ito dell service center and they have...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
But, if you paid for the Dell service, Dell needs to fix the problem. Sounds like they replaced the motherboard with another faulty one.
Hope this helps.
Feb 12, 2011 | Dell Inspiron 1520 Motherboard
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Solution for ''the power light for dell inspiron 1520 turns on for about 5 seconds and goes out
If there is a yellow light on the front panel, indicates a faulty AC adapter. If you know someone with an Inspiron 1520, test with their adapter.
Jun 13, 2009 | Dell Computers & Internet
The screen is blank but I can see a faint image.
Try reseating the cable that goes to the back of the lcd and also the other end of that cable that plugs into the motherboard. If that doesn't do it then either the lcd or the inverter is bad. Either way when you get a replacement screen for a dell laptop it normally comes with a new inverter as well. If your laptop is under warranty thru dell then you can get it replaced thru them. If you have your serial number then I can look it up and see if your system is still under warranty.
May 26, 2009 | Dell 0JM629 Inspiron 1520 Keyboard
I have a dell inspiron 1520 that is 15 months old doesn't go on
Generally, if the AC adapter for the system's LED goes out when connected to the system, check the battery and see if it is holding a a charge (Press the button next to the LEDs on the battery see if all 5 light up)  If the battery still has power, then most likely there is a failure of the motherboard.
If you can, try another Dell D-series AC adapter and see if the same thing occurs.  If the system powers on, replace the AC adapter, if not it is a motherboard.
May 19, 2009 | Dell Computers & Internet
Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Mar 22, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Laptop Logo
2,037 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
