Question about Whirlpool 24 in. DP840D Free-standing Dishwasher
Dishwasher wont run..breakers ok...can hear click like a silinoid valve is opening when i turn the knob
  • smeng2 May 23, 2009
    the problem was in the door switch...it wasn't making connection
    Brigadier General:
  • 3,917 Answers
Sounds like you may have a food particle or something along those lines caught in your pump. Alot of dishwashers run the pump in one direction to wash and the opposite to drain. Try advancing the timer to a drain part and see if it dislodges whats in your pump. if this doesn't work, you may need a repair person.
OR
Indesit list that as an inlet valve failure.
You'll need a multimeter to check the valve, test it to see if the coil is open circuit, if it is, replace the valve.
Is the water turned on? Check the supply to the valve.
Check the wiring in the door hasn't snapped.
Finally check the pcb in the door to see if it's burnt or damaged.
OR
what you are hearing is probably the drain pump solenoid. At start the drain pump will get in to get rid of any water and purge the system. It's hard to tell without being there. I would call for service, it won't cost anything. Have the tech check the wash and drain pump assy
Thank You
Posted on May 23, 2009
Why does lawn mower click but wont start?-replaced silinoid still just clicks. Why
BAD BATTERY (SHORTED CELL) THESE BATTERIES DIE FOR FUN. DOUBT ITS THE STARTER BRUSHES.
Sep 08, 2014 | Garden
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
My Kenmore dishwasher is not getting water! I
John? did you pay your water bill this month? LOL
check your temp controll switch that feeds to water solenoids to make sure there is a voltage/ signal going to them also your load limit switch under the tub ? if it is stuck open it wont fill the tub! that could be a good possiblity
Jan 14, 2010 | Dishwashers
Quiet partner 1 will not drain or run
It sounds like it ain't getting any power since all your hearing is the clicking from the timer. If it does have power I would take the front panel off and see if everything looks ok and make sure there ain't any loose wires. But start with checking the wires coming in for power. Hope this helps.
Mar 08, 2009 | Dishwashers
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Dishwasher
A few things to check:
- is the timer running? The first thing the timer does is open the water valve solenoid. You should hear a click immediately before the water flows through the pipe. If you don't hear this click, then either the dishwasher has no power (check your circuit breaker), the timer is faulty, or the solenoid is faulty.
- is the water turned on? Obvious question, but I have to ask.
- is the hose kinked somewhere?
You didn't mention if the rest of the functions work after the fill function. If so, it must be either the solenoid or a water delivery problem. If not, perhaps the dishwasher has no power, or else it is probably the timer.
Sep 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Diswasher won't run
first check the circuit breaker box you might hva tripped abreaker, next close the door softly, and listen to perhaps hear the door switch activating, id the door doesnt close (bad switch) no power to rest of d/w
Feb 23, 2008 | Kenmore 15522 Built-in Dishwasher
Whirlpool 24 in. DP840D Free-standing Dishwasher Logo
70 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
