Recorded from mini digital camcorder (PV-GS65)--converting mini tape to DVD. Used a Toshiba DVD-R (D-R410) to record. Used s-video cable, not issue with video recording, but when played back no audio. Cannot figure out how to transfer sound from camcorder to DVD?
  • 1 more comment
  • guycaiafa May 23, 2009
    With the s-video cable? This is a mini Panasonic camcorder--are there places to plug the cables into the camcorder?
    Sorry--I'm a novice, as if you didn't already know!
    do I plug into camcorder while also using s-video cable?
    I have a mini Panasonic digital camcorder. In the manual it said you could convert the mini tapes to a DVD by using an s-video cable into the DVD-R. I plugged S-video from camcorder to DVD-R and the vido portion redcorded fine. The problem is, there is NO audio recorded. Any thoughts?
  • 749 Answers
Have a look in the manual it will show you dow to do it.
Posted on May 23, 2009
  • 3,230 Answers
You need to plug the RED and YELLO wire Cable from Camcorder to DVD.
Thanks
  • Mukesh Kumar May 23, 2009
    No its the normal Audio Video Cable.
I have a Panasonic PV - GS65 mini dv . When i press record it works for a few seconds and then it stops and tells me to push the reset button . After that is don it continues to do the same thing
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Nov 07, 2010 | Panasonic PV-GS65 Mini DV Digital...
PV-GS65: Tape won't come out
u must open the camera and just remove motor connector and put 3 dc volt suppy on motor then it will wok
Jul 08, 2009 | Panasonic PV-GS65 Mini DV Digital...
Missing instructions and no cables to attach to T.V.
yes, you can use generic cables to get camcorder picture in tv to burn dvd in dvd recorder attached to tv.
Please intimate model number of Panasonic camcorder to look for instruction manual for you.
Apr 09, 2009 | Panasonic Palmcorder PV-DV53 Mini DV...
Upload content from PV-GS65 to LAPTOP
there should be a usb port on the camera. below the mic in, under the flap to the right of the on/off.
should be able to get this cable at any office supply/ camera store.
Jan 13, 2009 | Panasonic PV-GS65 Mini DV Digital...
Power save function
Do you put a tape in when you try to record or do you connect to a DVD / VCR so that it records onto the DVD or VHS?
If this is how you do it, then I will recommend you use a mini DV tape instead.
Hope this helps.
Osei71
Sep 10, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Jun 29, 2007 | Panasonic PV-GS65 Mini DV Digital...
Convert NTSC VHS video tapes to DVD PAL
If you do not have an adaptor to play the tapes to a standard VHS viseo player, you can use the camera as the player by connecting the AV out to a DVD recorder. There are hundreds of models in the market, and do not worry if it is NTSC or PAL because 99% of DVD recorder accepts both.
May 23, 2007 | Panasonic PV-GS150 Mini DV Digital...
How to Record From a TV Using PV-GS13?
connect a lead via your tv video out audio out jacks. Select tha appropriate channel (You may have to go through the av channel on you tv and tune in the channel you want to record) or, video or dvd player audio out video out jacks. connect other end to your camcorder. Select on the camcorder menu video in audio in. Turn on tv. If connected to video or dvd player, press play. Press record on your camera. When finished recording press stop. Presuming the camcorder is tape, you can buy a tape adaptor to play or record your mini tapes in a standard video recorder, then take them out of the adaptor and play them back on your camcorder. You can also do all this via a computer. Also if the camcorder is disk or hard drive it can be used the same way as a regular dvd recorder to record tv programmes once connected to you t.v. Let me know how you go 26 red
May 08, 2007 | Panasonic PV-GS31 Mini DV Digital...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
