Question about KitchenAid Kitchen Ranges
Kitchenaid electric range model KEDT105V F-2 beeping when it feels like. Stove and oven are not in use.
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Model KEDT105V F-2 and F-3 flashing and beeping
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Posted on Mar 25, 2009
mgprice
  • 744 Answers
SOURCE: KitchenAid KEDT105V Electric Stove - f-5 beep
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Posted on Mar 25, 2010
Kitchenaid stove code f68
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
800-422-1230
Jan 03, 2014 | KitchenAid Electric Stove Range...
KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
New Kitchenaid stove used 1st time turned oven off now beeping
Hello! Yes, I did figure out the beeping...while on a long hold with the kitchenaid helpline, I took the "cookie sheets off of the top of the stove" and voila the beeping stopped. Simple, but who knew? I hope this helps someone else.
Jan 10, 2009 | KitchenAid KGST307 Gas Kitchen Range
Off button doesen't shut off oven
You will probably have to replace the electronic range control.
Jan 03, 2009 | KitchenAid KESC307 Electric Kitchen Range
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
F1 error code on comp screen of wall oven
The solution is people to find yourselves a better website-this one is full of problems and no solutions!!!
Jul 25, 2008 | Kitchen Ranges
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Open Questions:
Kitchen Ranges Logo
96 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
