Question about Polaroid FLM-323B Television
Flm-323b Blowing Fuses
This Tv is blowing fuses Shown is a partial schematic and a data sheet of components involved.
Q2 and he Zener on the source were shorted. I replaced Q2 with a FVP 11N60 and the zener. I then had 5VSB and led lit. I hit the on/off switch and the led turned blue then in about 5 seconds the fuse blew again. Q2 and the zener are shorted again. The source has 5 resistors to ground all marked 1R5 which I take to be 1.5 ohms.
I did peplace the 2 infamous caps in this power supply BTW this is a 200-P00-MLT666A-AH I do have the full schematic and working on a parts list with Mouser stock numbers and digital macros of trace brd to sell later on.
There are no other signs of bad components or ohmed shorts.
schematic http://cabaret-karaoke.com/fix/_1.PDF
data sheet http://cabaret-karaoke.com/fix/Q2.pdf
  • 1 more comment
  • karyoker May 23, 2009
    I did misread the transistor It is an 18N60 which is an 18 amp versus 11 amp....(11N60)
  • karyoker Jun 07, 2009
    The SMD markings are 470 on both I do have the schematic for the AH it should be similar.
  • James Hazel May 11, 2010
    One thing you should get is an esr meter so you can check all the
    electrolytic caps on board as it saves time. I am having a hell of a
    time trying to find schematics for this board. So this board is used in
    POLAROID 2611-TLXB and FLX3211B Element LCD TVs. My board is
    200-P00-MLT666A-BH which i think is very similar to the
    200-P00-MLT666A-AH. I checked the back of the board and can tell that
    R47and R48 are burnt and I can't see the values. Do you know the values?
3 Suggested Answers
SOURCE: I picked up one off of ebay too and trying to figure it out...
Hi, both are 47R
They are labeled 470 i.e 47 and no zero's
Posted on Sep 23, 2009
SOURCE: flm323b power supply
Replace Q2 by 18N50, Q8 and Q9 by STP6NK60 and Z2 and Z4 by !n4739. I have the same problem and fix it.
Posted on Sep 30, 2010
Qsc mx 700 keeps blowing fuses after replacing all transistors with replacement parts not original
Have you replaced the IC , Q2 and Q2?
• Check the Differential Inputs ( IC1 ) and sorrounding components
• Check the Driver Stages
additional guides or suggestions:
Cross wired speakers and blown power transistor.
Beware also of counterfeit Power Transistors
Aug 05, 2012 | Audio Players & Recorders
It was runing but now the kept blowing a #15 fuse and now i replaced the fues and its still not starting but before that when i replaced the fuse it would start back i think its the fule relay fuse i...
Any and all issues involving anything electrical,
require a partial or complete set of wiring
diagrams of your car.
Sort of a road map to follow, to find
the cause and fix
Without that, even a repair shop is wasting
their time
So you need a repair shop with a data base
& necessary schematics
Apr 26, 2011 | 1987 Toyota Camry
Where are the fuses that are mentioned and what do they look like? I have the back off of mine and it looks exactly like the picture above.
Hello Gary, you can find the fuses on the power supply board which is located inside the TV, they look like medicine capsules made from glass and for contact capped with a sheet of metal. Here is a picture of a SAMPLE LCD power supply board. cyberdyers.jpg
Nov 22, 2010 | Polaroid FLM-323B Television
Flm323b power supply
May 22, 2009 | Polaroid FLM-323B Television
No Power to LCD Tv
Even if caps do not look blow, they still can be. Check diodes and resistors on power board. Easy fix if you have patience and time. make sure you replace with a higher voltage, but same cap, resistance values.
Dec 27, 2008 | Polaroid FLM-323B Television
Humminbird fishfinder keeps blowing 5v fuses .Power ok to base but as soon as you attach fishfinder fuse blows
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Humminbird GPS
FLM-323B 3200
Check the fuse first next to the cord on the TV
Aug 22, 2008 | Polaroid FLM-323B Television
Polaroid FLM 323b
The 2 1000mfd cap that are 10 volts should be replaced with 1000 mfd 16 volts at 105 deg. All the caps need to be high temp and high grade.
Fuse ,zener diodes keep blowing.....
hey eriez
if your familiar with repairing tvs, this aint that hard. just locate the blown fuse and the zener diode. and look for scalded and burnt component parts as well....
unfortunately, there is no free service manual found on the net today for your JVC CA-V808t... however, there are lots of sites that sell them though..
any thoughts that you want ... just post it here...
Apr 08, 2008 | Audio Players & Recorders
Tv dont work with surround sound
It is important to remember that you will not get digital audio out unless your source into the unit is digital, such as digital tuner or Hi Def cable or sattelite.
Feb 20, 2008 | Polaroid FLM-323B Television
Polaroid FLM-323B Television Logo
1,058 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
