Question about Canon PIXMA iP5000 InkJet Photo Printer
Where can I buy the waste ink absorber pads for both printers?
I have the Canon ip4000 and ip5000 ink jet printers. I need to replace the waste ink absober pads on both printers. Where can I buy the absorber pads? J Tom Dougherty jtomdcapital@yahoo.com
  • 4,041 Answers
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Error message 1700, waste ink absorber nearly full. Can I get the part to repair this myself?
Unable to advise about part availability, but..
This is a very mucky job and requires printer to be almost fully dismantled. This can be done if you are good with this sort of thing.
Then all waste ink would need to be washed out with water, pads fully dried and then rebuild printer.
Dec 19, 2014 | Canon PIXMA iP5000 InkJet Photo Printer
Error code 1700 on Canon IP5000
You can clean the waste ink absorber (dirty job) and reset the waste ink counter.
See download links below for service manual and howto:
http://www.hsx.dds.nl/service/iP5000sm.pdf
http://www.hsx.dds.nl/service/iWasteInkTankFull.pdf
Dec 20, 2014 | Canon PIXMA iP5000 InkJet Photo Printer
My printer says that the ink absorber is full and the unit will not print, how do I clean or repair?
THERE IS A SIMPLE SOLUTION TO THIS PROBLEM ...
I used some of the "Cartridge Flush" solution ... I squeezed some onto the waste ink absorber pads (Black & Colour), using my ink refill needle, and then I used soem paper towels to soak it up from the ink absorber pads.
NO MORE MESSAGES!
... hope it works for you as it worked for me!
Feb 01, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
Waste ink tank reset
Google is your best bet for a question like that, where did you get the instructions to reset the waste ink absorber?
Look there also
Jul 18, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
I get error message 5B00 waste ink absorber full. What should I do?
Hello
Replacing the waste ink absorber is a service procedure which is not documented in the user manual, it is documented in the service manual.
the part needs to be replaced and then the printer needs to be reset, this can be performed with either a button combination or with a service tool, which is only available to service personnel.
it would be best to send this printer to canon for repair.
May 29, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Empty the overflo ink tank on a canon ip5000 printer
The waste ink absorbers on a Canon are pads that are under the print engine and cover the whole bottom. It is a major dissasembly where the covers come off, cables and plugs un plugged, power supply removed, and then you need a shop to reset the counters.
Aug 28, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
1,119 people viewed this question
old marine
old marine
