Question about HP OfficeJet 6110 All-In-One InkJet Printer
Can't receive or send faxes
There is not dial tone or sound of numbers being entered.  The phone line works because when I dial the number for the fax the phone rings.
  • toddass Oct 22, 2007
    Appreciate the effort, but didn't help.
  • toddass Oct 25, 2007
    The phone line was bad.  Phone company fixed it.  Good to go now, thanks.
  • HP Master
  • 1,113 Answers
Are you pressing the speaker/hook/manual dial switch (not sure of its label)?
Make sure phone line from wall is connected to fax's line socket not the ext. one
Is it in Fax mode? Can you copy OK?
Posted on Oct 21, 2007
  • Soulvisitor
    Soulvisitor Oct 24, 2007
    Button stuck on keypad is a possibility, so is it not being in fax mode,also I have a question, if you dial a number from the fax does it ring dialed number and you are just unable to hear number being dialed?
    You could hook up ext phone to fax and see if you can dial via that too,
    Is it in fax mode?
    Can you copy/print ok ?
SOURCE:
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Can not receive or send faxes???
If your fax machine was working before this could be a line problem. Call your fax number with your cell phone or another phone. If you get a message phone the phone company or it just rings busy its probably a line problem. Another check is to plug your hand set into the wall outlet jack, you should hear the dial tone. If there is no dial tone its also a line problem. Or just try pluging your fax machine in at another location, if it works there you know its a line problem. If its still not working its going to be one of the boards inside the fax machine. Good luck.
May 16, 2010 | Office Equipment & Supplies
Cant install fax software for lexmark x5495 aio printer.
1. Unplug the printer from the PC
2. Uninstall all the software related to the All-in -One ( that is on the PC)
3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
From the instruction manual:
Sending a fax
Entering a fax number
1 From the control panel, press Fax Mode.
2 Enter a fax number using:
The text box Enter a fax number using the keypad.
Notes:
• You can include a calling card number as part of the fax number.
• Enter a maximum of 64 digits in a fax number.
• Press Pause / Redial to insert a three-second pause in a number you
are entering to wait for an outside line or get through an automated
answering system.
Speed Dial or Group Dial a Press Phone Book.
b Enter Speed Dial and/or Group Dial numbers.
• Press or repeatedly until the Speed Dial or Group Dial
number you want appears.
• Use the keypad to enter the number of the Speed Dial entry (1–
89) or Group Dial entry (90–99).
Notes:
• For instructions on how to add Speed Dial or Group Dial numbers
using the computer, see “Setting up Speed Dial” on page 118.
using the control panel, see “Using the Phone Book” on
page 108.
3 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
been entered.
Sending a fax using the software
You can scan a document to the computer and then fax it to someone using the software.
1 Load an original document facedown in the Automatic Document Feeder (ADF).
2 From the desktop, double-click the Productivity Studio icon.
3 From the right pane of the Welcome Screen, click Fax.
4 Select the Document option.
5 Click Start.
6 Enter the recipient information, and then click Next.
Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
Faxing
103
7 Enter the cover page information, and then click Next.
8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
9 To send your fax:
• Immediately—Select the Send now option.
• At a scheduled time:
a Select the Delay sending until option.
b Set a time and date.
10 If you want a paper copy of your fax, select Print a copy of your fax.
11 Click Send.
Sending a fax using the control panel
1 Make sure the printer is on.
2 Load an original document facedown into the ADF or on the scanner glass.
Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
clippings) into the ADF. Place these items on the scanner glass.
3 From the control panel, press Fax Mode.
4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
information, see “Entering a fax number” on page 103.
Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
5 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
6 Press Start Color or Start Black.
Sending a fax while listening to a call (On Hook Dial)
The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
printer. It is useful when you must navigate an automated answering system or enter a calling card number before
sending your fax.
2 Press .
3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
the telephone line.
4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
Note: Press the keypad numbers to use an automated answering system.
5 Press Start Color or Start Black.
Faxing
104
Sending a broadcast fax at a scheduled time
You can send a fax to a combination of up to 30 people or groups at a time you choose.
1 Load an original document facedown into the ADF or on the scanner glass.
2 From the control panel, press Fax Mode.
3 Press .
4 Press or repeatedly until Delay Fax appears.
5 Press .
6 Press or repeatedly until Delay Until appears.
7 Press .
8 Enter the time you want to send the fax.
9 Press .
10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
11 Press to save your settings.
12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
14 Press Start Color or Start Black.
Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
dialed again.
Receiving a fax
Receiving a fax manually
1 Make sure the Auto Answer light is off.
2 To receive the fax if you have not set up a manual answer code:
• Press Start Color or Start Black.
or
• Press * 9 * on the telephone after you answer it and hear fax tones.
3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
and hear fax tones.
Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
code.”
4 Hang up the telephone. The printer receives the fax.
Faxing
105
Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
Can't send or receive fax hagans@loadednet.com.au
Check the cable, i.e. plug an analogue phone into the cable and listen for a dial tone. If none, are you plugged into a digital line?
If a dial tone is heard, is it an intermittant dial tone (message waiting) because this can stop the fax from working. If so, resolve this and try again.
Do you need to dial a number to get an outside line? If so this needs to be entered before the fax number on outgoing faxes.
Nov 17, 2009 | Canon MP830 All-In-One Printer
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Cannot send or receive faxes
How to dial *xx codes when faxing When sending a fax, it may be necessary to enter in a *xx code as the first part of the number. Follow the steps below to dial *99 when using a VoIP service. NOTE: Since the *xx code is an instruction to the phone system, this must be dialed live.
  1. To pick up the line on the HP All-in-One, press Start Black Fax or Start Color Fax without entering a phone number first.
  2. When you hear the dial tone, enter in the *99 code.
  3. Wait a few seconds and then enter in the rest of the number.
  4. The HP All-in-One will complete the fax as normal.
What can be done to help the fax transmission? The communication speed is a major factor in fax transmission over VoIP. Currently there are three speed standards.
  • Fast - v.34 which communicates at 33.6 Kbps.
  • Medium - v.17 which communicates at 14.4 Kbps
  • Slow - v.29 which communicates at 9.6 Kbps
Changing the Fax Speed Adjustment setting to Medium may improve your ability to send a fax over a VoIP network. On most HP fax products the connection speed can be set to a lower speed. Those that do not have a Fax Speed setting generally communicate at medium speed or lower as this was the past standard. Consult your user's manual for information specific to your model. Changing the Fax Speed Adjustment to a lower speed Follow the steps below.
  1. Press Setup .
  2. Select Advanced Fax Setup .
  3. Press OK .
  4. Select Fax Speed .
  5. Press OK .
  6. Select Medium .
  7. Press OK .
  8. Try the fax again. If you continue to have problems faxing, contact your VoIP provider as they may have options to improve the ability to send and receive faxes over VoIP telephone service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon Faxphone L80 - Alan Silva
To send a fax you do not need to enter anything into your fax. You have to make sure that you connect the telephone line to it's desgnated connector. You dial a number to send as if you are calling form a normal phone. If you ever get a ringing tone press start. You can enter any data trough the data registration after you make sure your fax is functioning properly.
Jun 24, 2008 | Canon FAXPHONE L80 Laser
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
78 people viewed this question
Clive
Clive
Thomas F. Schneider
