Question about Frigidaire FWS833A Top Load Washer
Belt will not turn
The belt will not turn on the washer and it starts to smoke. What will cause the belt not to turn
  • 4,889 Answers
You probably have bad spin tube bearings. Look above transmission for a water leak or evidence of one.
Posted on Oct 19, 2007
Smoke come in out while spinning
Don't know what machine you have if it has a belt check it. Take belt off & see the motor turns freely also with the belt off see if you can turn the drum if one of them won't turn the belt will slip & cause burning smell. Small clothes getting under the agitator even sometimes in the pump can cause this , check under agitator & check the pump it may not turn if a sock or something gets in it & this can cause the belt to slip. If these seem ok put it in spin & watch the motor it could have a short & will smoke. Good luck
hope this helps.
Nov 22, 2017 | Washing Machines
My washing machine after it has done the wash, it spins but when finish the clothes are still soaked and i smelt a buring smell
Check your belts and replace if faulty, sounds to me your belts are slipping and causing smoke. you may have a smoking solenoid or board.
turn the pump by hand with belt off to see if pump is jamming
Oct 28, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a five year old Amana Commercial washer. The washer started smoking on the rinse cycle and I didnt realize that it wasnt spinning. Is the part to fix this reasonable or should I just replace the...
Well their are several possible things that can cause that;
The transmission pulley did not properly disengage the brakes so in the spin cycle the tub didnt turn to cause the belt to slip and smoke and burn
thier is something obstructing the tub from turning on the spin cycle so again the belt slipped and smoked
the tub bearing is locked up so once again the belt......
so it may worth a service call to determine what the cause is,surely a belt will be needed but need to know why the belt is burning
Gene
Aug 11, 2011 | Washing Machines
My wife noticed smoke right after starting the washer. She immediately turned it off and called me. I noticed a smoke smell which smelled more electrical than rubber. The basket spins easily. The washer...
Thanks for choosing FixYa and welcome to the site. There are a few things that you can check. First, check your belt. It may have worn or the pulley may be sticking. The belt may be causing the smoke. You might want to check your control board just in case and see if you see any damaged wires. You need to try and see if the washer throws out any error codes. I really don't know what else you could check because there are no symptoms. It could have come from the water pump or the motor drive also.
Apr 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
We have a stackable kenmore washer and dryer. The belt started to slip and smoke on a heavy wash load. I replace the belt but it still smokes and wont spin. Is there and adjustment?
Hi, There are no adjustments. Make sure the pulley on the idler and the drive pulley are tirning freely. It is possible the transmission is locked up and the belt will not turn properly.
If all the pulleys are free, start the washer in the spin cycle while watching the drive pulley to see if it turns.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 94802 washer belt overheats, smokes, and melts
sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Apr 08, 2008 | Kenmore 94802 Front Load Stacked Washer /...
Stacked kenmore tranny problem?
yep. belt started smoking because motor is turning and not the tranny.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FWS833A Top Load Washer Logo
74 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
