Question about GE GSH22JFR Side by Side Refrigerator
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
It's making a fairly loud ticking sound--about once every second-sounds like a big clock. Ice maker works, but not ice or water in door.
  • jcricket May 23, 2009
    Thanks so much for your quick reply!
    It just doesn't seem like the water line to the ice maker could be frozen--it's still making ice cubes.
    It's just the ice/water dispenser in the door that's not working.
    Any other ideas?
  • Anonymous May 24, 2009
    Just keeps on ticking!
    I thawed freezer and let it set for a little over 4 hours as suggested. But the minute I turned it back on, it began to 'tick' again, and hasn't stopped.
    By the way, the green indicator light blinks in time with the ticking, if that means anything.
    Can you think of anything else I can try?
  • 63 Answers
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
Posted on May 23, 2009
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge model 20, 22, 25 side by side refrigerator. A loud clicking sound from the back of the refrigerator. It sounds like a clock ticking on the second. No water is being dispensed and when I push on the...
there is a mother board in the back that go bad the clicking to hear is the micro switch on the board try to cick in but when they go down you need to replace the whole board :(
Jan 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Loud continuous ticking sound, freezer cold but refigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 27, 2009 | GE Profile Arctica Stainless Steel Top...
I have a GE SxS that I bought in Sept. 06. About
First you need to turn the freezer temp control back on(That just turned the whole refrigerator off)
The water dispenser may have stopped due to line freezing inside the refrigerator.
The ticking could have been the the element for the defrost cycle or the starter on the compressor.
So,turn it back on,set the temp to a normal setting and if the ticking is still there,wait 30 minutes to see if it stops,If no ticking is there when you restart it,wait 24 hour and check the temp inside as well as the water and ice dispenser,If all work,It is a defrost issue.If so you will either need a defrost timer,defrost element,or defrost thermostat.
If the ticking is still there,You will need to replace the start/run capacitor.
Apr 16, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ticking noise
this is the motherboard part number 2252189 it is getting ready to go out but before you replace motherboard make sure the unit is grounded a bad ground can also make the same problem happen
check ground at wall and all green wires on or around compressor and door hinges
Dec 06, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE side by side fridge with Water and Ice despenser
djones, The evap fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evap fan motor. If this voltage drops out or fluctuates, it's more than likley the board....Catriver...post back.
Dec 12, 2006 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSH22JFR Side by Side Refrigerator Logo
394 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
