Question about AOC Envision Peripherals 416V TV
No signal AOC TV
Input no longer offers TV as a choice, only AV, PC & HDMI...
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
SOURCE: buttons locked on AOC 24'
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
Posted on Sep 25, 2009
SOURCE: My cable input has disappeared.
I also have this problem. Also, if I switch the input to PC or HDMI, it will no longer allow me to go back to AV.
AV itself doesn't quite work. When I turn on a peripheral, the TV seems to register the machine, but doesn't properly display it. For instance, if I turn on a game system, the screen switches from "No Signal" to grey. Another interesting thing is that when powered on, the intro screen that is usually blue displays as grey.
I'm chalking it up to a software issue, so my solution would be to find a way to reset it to factory settings, but I can't find any way to do so in the manual or online.
Posted on May 29, 2010
I would like help with setting up....I have the cable from the digital cable box going into the TV and still saying that is not receiving a signal
Without more details it's hard to answer this, but here goes...You should have a button on your remote that says "input" or "Source". Use your remote to check what the input is set to. Change the input and see if your signal comes in. There will be several choices. If you have a digital box it has an HDMI port, so does your TV. Normally the cable box HDMI goes into HDMI 1, or 2 on your TV. The cable just screwed into the cable inlet o the TV will be something like "AV" or "AV1" Ideally, you want to run one HDMI cable from the box to the TV. It carries sound, high def video etc; It's the only cable you need. let me know if any of this helps.
May 03, 2015 | Televison & Video
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Inputs will not change on a envision aoc tv
Try a factory reset. This might re-enable the other functions.
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Jan 13, 2014 | AOC Televison & Video
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
Settin TV to AV
Look at your remote for a button called "input options" and press that button while watching your screen to see the various choices available. Everytime you press that button, you should see a change on the screen from one choice of input method to the other. It should says things like "AUX, video 1, video 2, hdmi, AV - ect. Keep pressing that button until you see a picture of find the AV input method you want to keep and that should solve your problem.
Apr 15, 2012 | Sony Televison & Video
It will not automatic default to hdmi when powered on, and the only thing connected is the hdmi, but i must select it how do i default the tv to hdmi
There is a button on your remote control to change the input method. You press the button to change it. Examples of input choices are AUX, Antenna 1 & 2, cable, tv, hdmi. Keep pressing the input button until you see a picture or find the HDMI choice. That should solve your problem.
Oct 31, 2011 | Televison & Video
My cable input has disappeared. All I have are HDMI, AV, and PC inputs. And the entire selection in the menu for channels is gone including auto channel scan.
- Press Menu
- Press 991
- Go down to Memory recall and press enter
- It will ask you "ARE YOU SURE"?
- Select "Yes" and press enter
- It will take you back the menu screen, turn off the TV and turn it back on user_offline.gif quote.gif
May 18, 2010 | AOC L22W898 22 in. LCD TV
AOC Envision Peripherals 416V TV Logo
561 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
