Question about Bosch SHE5AM02UC Stainless Steel 24 in. Built-in Dishwasher
Error code E:24
Hi, we have a Bosch SHE5AM dishwasher. The display reads E:24. Would you explain this error code & possible issues please? Thank you.
Bosch logixx error code: e24?
Posted on Sep 20, 2009
1. Turn it off
2. Turn it back on
3. Hold the start button for 10 secs
4. Let go and you should hear the pump run for 1 min. The unit will reset
5. You should be good to go
Posted on Mar 21, 2013
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
May 20, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have pf code on the display already changed the control board same code as befor
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Feb 05, 2011 | Frigidaire Professional Series 24 in....
Fon the dishwasher
Hi, welcome to Fixya.
Based on the info you've provided, the dishwasher is indicating a error during the "fill" stage, hence the "F" being displayed on the Bosch machines.
Here's how to perform a test or diagnostic...
Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ).
Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ).
When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time.
Let the test follow through, ( grab a coffee and observe, this will take a while )
When testing has ended, the display will show an error using codes as follows...
"0" = no error.
"1" = aqua sensor fault.
"2" = heating fault.
"4" = filling fault. and finally.
"8" = NTC ( temperature sensor ) fault.
The "F" code will not appear in test mode, only during wash. If you have a failed level switch for instance the test will display "4" and will continually fill and drain and test won't complete until you press the "on/off" button.
If the test complete's without and error or won't fill, replace the water valve. Original part Part # 425458 at "searspartsdirect.com", "apwagner.com" or #1105846 at "repairclinic.com" ( they use there own numbers ) or you can check locally by your model number & serial number.
Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating.
Thank you for choosing "fixya" and good luck.
macmarkus :)
Jul 07, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch dw gives a error code of 1 this is an over or under water filling fault not a heating error which is posted on this site which one is correct
Hello, welcome to Fixya. Actually an error code "1" refers ONLY to a heating error. I'm not sure what you've based your info on, but "1" being displayed has nothibg to do with a water fill/level issue what-so-ever with any Bosch dishwashers. Here's how to perform a test or diagnostic for the "shu43" series Bosch to determine once and for all the problem you're having though. Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ). Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ). When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time. Let the test follow through. When testing has ended, the display will show an error using codes as follows. "0" = no error. "1" = aqua sensor fault. "2" = heating fault. "4" = filling fault. and finally, "8" = NTC ( temperature sensor ) fault. If it where related to a fill/level error you would see the letter "F" during washing but the # 4 in diagnostic's. Similarly for a heating fault, the diagnostic will identify a #2 but the "1" appears during normal washing. Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating. If there is anything not clear let me know and I'll try to expand on the info I posted. Good luck. Macmarkus :)
Jun 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Jul 07, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Hotpoint
hope this helps u... all the error codes and faults, they can be found here>>>>>>> http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
please vote thankyou
Apr 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Bosch SHE5AM02UC Stainless Steel 24 in. Built-in Dishwasher Logo
8,429 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
