Canon pixma mp830 multifunction unit, copier/scanner do not work. will print from fax or computor only.
  • ewootton May 25, 2009
    The Scanner tries to warmup but finally gives an error code of 2178.0
    could the light source be inop and if so can I fix it myself.
    Thanx
    Ed
    Brigadier General:
  • 8,619 Answers
Hi
Please try this to clear the error code--
  • Open the CanoScan Toolbox.
  • Click the Save option.
  • Put a check in the box that states "Display the Scanner Driver".
  • Click Scan.
  • Click the Advanced Mode tab.
  • Make sure Select Source is set to "Platen".
  • Click the Preview button at the top left.
  • If the error still occurs, then most likely it will be a service issue.
Check if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner. If not then there is a loose/faulty FAU cable(cable which comes out of the back of the scanner and into the lid). Try to jiggle it a bit to check if it works. If it doesn't work then one, or more, of the eight wires within this cable has fractured and unless you are handy with fine wires and a soldering iron, it's off to the scanner shop.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 25, 2009
    Brigadier General:
  • 3,917 Answers
not sure if the code is 6800 or 6A00 Issue: Error code 6800 appears on the display (multifunction printers MFP)
Solution: The MP830 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
http://www.usa.canon.com/consumer/contro...
Find a Service Location
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
* Obtain Support by Email
* For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
* Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752.
* Technical Support is available for Customers in Canada at 1-800-OK-CANON.
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
OR
I tried everything. I unplugged the machine and moved the printer cartridges to the far left and cleaned and pressed down the spring loaded sponge on the right, over and over again. I also moved the springloaded thing (w/white plastic) forward and backward. Another suggestion was to move the print cartridge holder back and forth sideways. None of these things helped. And there was nothing visibly out of place. I was stumped. Then I found a thread that suggested Windex!!! Even though the error seemed to correlate with a paper jam that had occurred, I was ready to try anything. I got paper towels and windex (I didn't have an eye dropper). I sprayed the paper and cleaned where the cartridges normally sit. Nothing. In desperation I sprayed each pad below the cartridge in the middle area and I sprayed the "sponge" thingy to the right. Really soaked it. Cycled the on/off about 3 times and IT WORKS! (Fingers are black but that's a minor issue compared to unhooking and transporting and waiting and paying for service...) When you cycle the Windex through it soaks up the sticky dried up ink and cleans things up. Don't use other cleaners--use Windex or water.
Thanks
Posted on May 23, 2009
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon Pixma MP830 will not send faxes. Instead
ASF sub- roller
cleaning
When the paper fed from the ASF is
smeared due to ink mist attached to the
ASF sub-rollers.
Sep 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp830 printing paused
GO ONLINE AND TYPE
CANON PIXMA MP830 INKJET PRINTER PAUSE PRINTING
OR
CANON PIXMA MP830 PRINT PUASE
OR
CANON PIXMA MP830 FORUMS USERS GROUP
ROD
Feb 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My fax is jammed and not printing does sender get an OK?
IF your scanner is working then you can send faxes it will stored in the printer memory and then send the fax..
Good luck...
Nov 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 Error Message: Scanner is not operating correctly.
This problem sucks. It sounds like the scanner has actually gone bad. This can be a couple of things. The actual ccd unit inside the scanner, a position sensor, a motor or a wire harness.
The latter two are fairly unlikely, the first two more likely. Most probable is the CCD unit. I don't think Canon sells it as a separate piece, but it comes inside a replacement scanner assembly. These complete scanner units are expensive. You'll have to check with your local Canon shop to see what they cost.
Nov 06, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner is not operating correctly...
You have to download MP Navigator if you want to scan
May 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
57 people viewed this question
jasbo
jasbo
