Question about Canon PIXMA iP90 Mobile Printer
Need help re aligning where paper goes
Paper jams up in my printer
  • simpleman021 May 23, 2009
    my printer has been droppedthats why i need help re aligning it
  • 544 Answers
HI,
can you open the cover of your printer and look again inside.
remember even a small tiny paper will caused this problem so if your rpinter is still having this problem then double check the printer inside.
thanks
Posted on May 23, 2009
When paper gets pulled in, it goes in crooked and jams
Make sure the paper is aligned and the guides are snug on the side. Also check the wheels to see if they are operating at the same speed.
This has happened to me in the past and the main cause was a wheel jamming or I had stored the paper in a humid environment. If the paper has been in a humid environment it will not feed properly.
Let me know if this helps.
Mar 20, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
The copy paper when inserted on the feeder tray is okay until I try to print. A page inserts into the printer and abrubtly stops making a stuttering sound and does not process through the printer. The...
Your gears are out of alignment or they are stripped out . Check to see if anything is inside to stop paper and create jam. It is a hardware problem and if you can find it by checking its not worth fixing.Cheap printer and it causes a lot of problems. not worth spending a lot of time on.
Sep 08, 2009 | Lexmark X73 All-In-One InkJet Printer
HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 30, 2009 | HP LaserJet P2015dn Printer
My HP P2015 reports a Jam when there isn't one
Logic:
Thanks and Regards
Jun 20, 2009 | HP LaserJet P2015d Printer
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
May 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Apr 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
How to align my paper
Remember- When ever u remove the carts form the carrier...u need to print an alingment page....(Start-programs-lexmark-solution center-maintenence -Click on "align to fix blury edges"..
For Paper jam
Check if any particles have fallen inside the printer...
Try to move the cartridge carries manuelly....move the roller...
Turn the printer up side down and shake it well but be carefull
Nov 17, 2007 | Lexmark All-in-One Printer with PictBridge
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
