Question about Garden
Flex shaft came loose inside aluminum curved shaft
The haed on my home lite trimmer was not spinning. Took it apart and the flexible shaft is not attached to the post assembly where the head attaches thus no motion. Can an entire new shaft be bought aluminum outer shell too with flex shaft attached? I don't have puller to remove post assembly to be able to reattach flex shaft.
  • ronerickson May 23, 2009
    Thanks so much. I'd done a search but couldn't find parts site. Thank you again . $42 part + 11.50 shipping beats getting a new one for $170. Thanks again!
    President:
  • 1,996 Answers
Here's a link to the homelite parts catalog site online.
You'll need your model # to look up exploded parts diagram for your trimmer, but you should be able to get any of the parts you need there.
On the other hand, depending on your location, a local repair shop, tool rental business or even a small auto or machine shop might be happy to do the repair and order the parts for you. I'd make some inquiries first, though, as at that point a new trimmer might be cheaper...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 23, 2009
I have a Poulan PP025. It runs fine; good acceleration and idle, several hours of great cutting; then the weed-eater suddenly ran as if out of balance, the head then stopped spinning. Any ideas?
curved shaft trimmers use a flex drive in side the case so that it can drive around the bend of the case
they are held in line with bushes spaced along the tube and this prevents the flex drive from binding back over itself
from your description of the problem, pull that flex drive out of the case and check for signs that it has a problem
the problem with bent shafts is that they will not handle any sort of a load and therefor are not suitable for heavy growth, heavy trimmer line or any metal/fixed attachments
the heat in the case will be from the flex drive rubbing on the inside of the case
Jun 06, 2016 | Poulan Pro PP025 17-Inch 25cc 2-Cycle...
Ryobi weed eater upper and lower shaft spins, but head doesn't spin, why?
If not a clutched model, likely the flexible drive shaft is broken. Check 1st to insure the engine head is firmly positioned into the aluminum shaft case. If it is remove at the engine, disconnect the cable as necessary and pull out the shaft for close inspection.
May 02, 2014 | Ryobi Garden
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Drive shaft not engaging
Hi there Reyles,
On this model, if yo rev the engine and the head just sits there, it can be one of two things.
  1. Clutch not engaging (unlikely)
  2. Broken flex shaft (likely)
You need to partially disassemble the unit to find out. I believe you will need a T25 or T27 torx head. Remove the screws from the clutch housing that connects the engine to the shaft.
Pull it apart. Spin the shaft manually. If nothing its the shaft. Otherwise its the clutch.
Best regards
Mike
Apr 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Nov 27, 2009 | Garden
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
What do i lubricate the flexible cable, inside the shaft of the line trimmer, with ?
I use a black molybdenum disulfide grease to lubricate the flex shafts. I remove the shaft, wipe off all of the old grease, apply a new coat of grease, and reverse the direction of the shaft when re-installing (top becomes bottom, bottom becomes top) to more evenly distribute the wear on the flex shaft.
Jun 15, 2009 | Homelite Mighty Lite Lawn Trimmer
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
May 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
260 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
