Question about Samsung PCL5415RB 54" Rear Projection Television
SAMSUNG PCL5415R I GOT A DOBLE IMAGE ON TV COULD SOME BODY HELP ME OUT BEFORE CALL TECHNICIAN
  • 3 more comments
  • HPMAN Oct 20, 2007
    IS NOT ONLY DOBLE,I JUST PAY ATTENTION,AND IS TRIPLE IMAGE, THE NORMAL WHITE LETTERS,RED AND GREEN, BUT THE -FUNY THING IS ONLY ON RIGHT AND LEFT SIDES, CENTER PART OF TV, SEEMS TO BE OK,COULD SOMEBODY PLEASE HELP ME OUT BEFORE CALL TECHNICIAN.   THANK YOU.
                              HPMAN.
    I ALREADY TRIED, THE CONVERGENCE OPTION ON MENU, BUT IS STOPPED AT 37% NOT LETTING FINISH THE PROCESS,
    I GOT ANOTHER QUESTION:THE CONVERGENCE BOX,IS THE PLACE,WHERE IS LOCATED,BOTH STK 392-040?
            PLEASE HELP ME OUT.
    THE  blown fuse (soldered-in) hidden under heat sink. IT LOOKS LIKE A DIODE?
  • lvfireman Apr 25, 2008
    i have the same problem. I can see blue ghosting. what can i do to fix it?
  • cman68 Nov 28, 2008
    The problem I have with my tv is that when you do the perfect focus it only does the green color and not the red and blue. Now you see like double and sometimes triple text and it is a little blurry. What can I do to fix it before I call a technician.
THANK YOU, TO TERRYFIC, HE WAS SO QUICK, TO ANSWER,AND TOLD ME THE RIGHT SOLUTION TO REPAIR , MY TV, I JUST REPLACED THE WHOLE CONVERGENCE BOARD, INCLUDING THE STK 392-040 IC AND READY, MY TV IS FIXED.
                                THANK YOU SO MUCH.
Posted on Oct 29, 2007
    Genius:
  • 1,694 Answers
Probable bad convergence IC's---STK units on large heat sink.
Also,possible blown fuse (soldered-in) hidden under heat sink.
Samsung is known for making the fuse devices hard to find.
Let me know if you need more help....T.
Posted on Oct 20, 2007
  • Vista Electronics Oct 20, 2007
    Fuse looks more like a resistor==has 2.000 written on it==
     2 amp.( just an example )
    Note:The IC quality must be best or will fail again.I use Panasonic brand with problem.
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
I have a convergence problem. Who would fix that? Someone mentioned that the convergence IC's need to be fixed. How?
The convergence ICs can not be fixed but you can replace them if you know to do that. The replacement cost around $7 to $15 each that mean $14 to $30 both . and a small labor of $45 if your technician is nice.
Good luck
Sep 23, 2009 | Samsung PCL5415R TV
Greenlines on pcl5415r
I suspect the convergence ics bad. samsung takes stk ic cost if you had it done is 250.00 If you can solder you could replace them , part are 30.00 total
good luck doctor video
May 18, 2008 | Samsung PCL5415R TV
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
SAMSUNG PCL5415
If the sound on your DLP TV is out of sync with your picture and the TV is not connected to a home theater system, a Samsung technician can adjust the sound sync function on the TV so that the sound and picture are in sync.
To arrange a service call to adjust the sound sync function, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864).
Dec 05, 2007 | Samsung PCL5415R TV
Red and Green flashes
Possible CRT coolant liquid leak onto circuit board.Check
for moisture evidence....................T.
Nov 03, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
May 04, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
169 people viewed this question
Jerry Greenberg
Jerry Greenberg
