Question about Xerox Phaser 850 Printer
Timing, jams or prints off bottom of page
Xerox 850 color printer had paper jam now prints off the bottom of page from manual feed and jams half way up from tray. Timing problem??
    Novelist:
  • 125 Answers
Hi hotpress:
Try these steps.
Print transfer jams
1.
If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
seated.
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
SB467.
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
Posted on May 24, 2009
My 3175 is jamming on the paper rollers each time I try to print. The paper feed through partially and then jams; with the printing done half way down the page. I have had a good look inside at the front...
That model has a problem with the exit sensor, it gives false jam errors. It is in the upper left side above the fuser. The part number is 0604-001393 and I believe www.precisionroller.com has the part.
Feb 04, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to Xerox.com, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Jun 17, 2009 | Xerox Phaser 8400 Laser Printer
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
May 26, 2009 | Samsung CLP-315W Laser Color Printer
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Mar 31, 2009 | Xerox Phaser 850DP Thermal Printer
Jamming on Output bin...
Ok if the paper is half way coming out, Two things could be happening.
1.) Either your paper feed tires are Slipping and haven't reached the outpit bin sensor in time.
2.) second problem could be is that the fuser film is worn and is not fuser correctly and needs to be replaced.
Are you getting an Error Codes ???
Mar 06, 2009 | HP Color LaserJet 2600n Printer
XEROX 8200 PAPER JAMMING
SOund more to me like you have worn out feed wheels. They are slipping when trying to feed, therefore you get a paper jam indication, but no paper has been fed. Check the feed roller texture. If it is slick replace the roller.
I will state that first. You could have a sticking sensor, but that is less likely if you say it feeds paper.
The second most likely problem is the paper feed or paper registration clutch failing. Those are electromechanical clutches that are located on the loerf front section of the frame. You would need to remove the left side cover ( looking from the front). The clutches are round and silver, about an inch and a half thick with black gears on them. If the clutch faces are slipping, the rolllers will not drive and result in a jam.
The more I think about what your describing, the more I believe one of your clutches is bad.
Sep 26, 2008 | Xerox Phaser 8200 Laser Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP 1020 Issue
Maybe if you hold down the cycle button and let it run through a "test cycle" to receive a printer data sheet it might clear the internal buffer or whatever you call that short term memory these printers have. Let us know. JP
Oct 17, 2007 | HP LaserJet 1020 Printer
124 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
