Question about NetGear DG834G Router
I need to connect two modem/routers to the Internet for my LAN
Dear FixYa Experts,
I have two modem/routers with two different DSL lines and two different accounts (could be diff. ISP or same ISP). I want the two routers/modems to work together for my LAN so I could get double speed and double data upload/download at a given time.
What are the things I should do to attain this configuration.
  • Patrick Kam May 11, 2010
    I think you'll need another router with configurable options for Network Load Balancing (NLB) plus 3 Network ports to connect to the 2 ADSL modem-routers and to your internal network. But note that you need to test the parameters since no 2 ADSL lines have same Upload and Download speeds.
    New Friend:
  • 31 Answers
Install an aditional cable and network card to the second router
Posted on May 24, 2009
My modem can not detect my lan card, i am using presario v3000, what maybe problem?
Greetings - I think you're not clear about how using the Internet works (not many people are - especially starting out).
The modem and the LAN card are TWO DIFFERENT ways of connecting to the Internet. The modem uses a regular phone line and the LAN card uses Ethernet (a different faster way of connecting to the Internet in which needs further hardware such as a cable or DSL modem from your ISP).
Or is it possible you're talking about connecting your LAN card to your cable or DSL modem?
If this is confusing to you please call the tech support of your Internet service provider and they should be able to walk you through getting connected..
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 17, 2011 | Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
What is difference between lan card and modem
The difference between a Lsn Card and a modem are this - A Lan card is a card that you slide into the side of a laptop and it can allow you the ability to get onto a network wirelessly. A Lan card for a PC allows a Lan connection by way of a CAT 5 cable that will allow you to get onto the internet or if a crossover cable is attached to your pc to another you are directly connected to the network. A modem is a piece of hardware that is installed into a slot in the PC that will allow you the ability to get onto the internet by attaching a phone line to it through the RJ 11 jack (which it comes with 2 rj11 jacks on it).
Here is the picture of LAN port and Modem port
Dec 24, 2010 | Siemens Computers & Internet
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Cant connect to internet using linksys with att dsl modem
Your router was configured for Cable Modem which is usually DHCP
Now you need to change it for DSL modem. This means you have to change WAN setting from DHCP to PPPoE and enter your Username and Password for DSL service (should have been provided by your ISP)
Some DSL modems that are also routers need to be accessed directly first and have their configuration changed to "passthrough". This means that DSL modem should not be handeling PPPoE login but rather should let your router do the login.
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Installing wireless G router
Yes, you do need a modem (DSL, Cable). This router does not function as a modem.
Oct 01, 2007 | Belkin (F6D3230-4) Router (F6D32304)
NetGear DG834G Router Logo
77 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
