Question about Weather King 10AJA3001AH Air Conditioner
The contactor well not pull in.
How can tell if it is the contactor or the circuit board in the furnace? the contactor well not pull in.
    President:
  • 1,902 Answers
Also if it where the circuit board that had gone bad. Your furnace would not turn on at all not even the blower motor. You can test them both by looking for 24 volts to the board, and 120 volts per leg of the contactor
Posted on May 23, 2009
We have Lennox Elite Series furnace and central air. Blower would come on but air cond. did not. He replaced circuit board ECG1, I believe. I don't think he was sure if that would repair problem. Our...
Look at the inside of the cover on the furnace and it will tell you what's the code mean.
I think because was calling for Ac that's why you are having that blinking red light.
Turn furnace off on switch and turn it back on and that should clear error code .
To check your air conditioning unit that's the unit that's outside .
Check to see if contactor is pulled in .if it is and nothing is running then check the capicator. The capicator is the oval metal thing that's tuck next to the capicator with 3 wires attached to it .
If it bulky then it's bad .
That is the most common issue with these unit.
Jun 01, 2017 | Heating & Cooling
How do i wire a 2e206 thermostat?
RED IS 24 V POWER INTO T STAT
WHITE IS HEAT GOES TO WHITE ONN FURNACE.
YELLOW IS COOL GOES TO THE CONDENSING UNITS CONTACTOR WITH SOMETIMES MAKING A CONNECTION ON THE FURNACES LOW VOLTAGE TERMINAL BOARD, LVTB, BUT IT NEED NOT, AS IT DOE NOTHING HERE, IT DOES OUTSIDE WITH THE 24V COMMON OR NEUTRAL LEG OF 24 V POWER.
GREEN IS FAN/HIGH/COOL SPEED AND GOES TO GREEN ON THE FURNACES LVTB.
COMMON IS THE 24 VOLT NEUTRAL AND WHERE EVERY CIRCUIT TERMINATES OR ENDS TO COMPLETE THE CIRCUIT.
Feb 23, 2012 | Heating & Cooling
It wont come on but everything has power not only will the air not come on but neither will the heat the thermostate has power and tells me the temp inside the contactor is realy realy hot
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Aug 26, 2011 | Ruud Heating & Cooling
My contactor will not pull in
If the contactor won't pull in the first thing to check is the low voltage circuit to the contactor. Is there 24v going to the contactor? If yes and the contactor is not pulling in, then you have a bad or dirty contactor. I have often time seen bugs get in between the contacts and stop the flow of electricity. If there is not 24v being supplied to the contactor then you will have to check your thermostat and the wiring from the furnace to the outdoor unit. Hope this helps
Aug 14, 2011 | Goodman Heating & Cooling
Randy2465@yahoo.comwhen you turn setting on thermostat to cool the thermostat clicks but outside unit and the inside fan neither come on?
Sounds like you might have a low voltage short possibly at contactor at outside unit (Condenser).
What happens is if your contactor has a short it will pop a 3 or 5 amp fuse at the furnace circuit board. This fuse will continue to pop until the short is fixed the best way I have found is to take off all low voltage wiring at furnace circuit board put them back one by one first with R then W then G then Y if it pops at Y your contactor has to be replaced.
May 11, 2011 | Goodman Heating & Cooling
Air conditioner compressor will not shut off.
Remove the cover on the outside unit that covers the circuit board and contactor and capacitor. Then start the unit and set the thermostat so that the unit cuts off. Then go back to the outside unit and see if the contactor is still pulled in and the unit is running. Next open the breaker and see if the contactor drops out. If it doesn't your contactor could be stuck. Try to free it or replace it. If not the problem could be in the circuit board.
May 26, 2010 | Carrier 38CKC036 Air Conditioner
Goodman GPM075-3 air conditioning connections
your thermostat powers 'Y' for cooling. That in your case blue wire connects to 'Y' on the control board in the furnace. Then a pair of low-voltage wires connects 'Y' and 'C' on the furnace to the two wires to the coil of the contactor in the a/c condensing unit. So to follow the path, the signal wire from the thermostat sends 24v down the Y wire to the furnace board Y terminal which also connects to one side of the contactor coil in the air conditioner. To complete the control circuit to the air conditioner there has to be a common wire. This is connecting the C wire from the furnace board to the other side of the contactor in the air conditioner. Hope this helps.
Dec 11, 2009 | Goodman Heating & Cooling
Contactor will not pull in
Check the cotactor coil for 24V. Leads on the side.
May 23, 2009 | Weather King 10AJA6001AH Air Conditioner
The contactor inthe outside unit well not pull in.
If the contactor will not pull in then the contactor is bad and needs to be replaced. They operate off of a small electrical pulse and they are made mostly of plastic so when then go bad they get stuck very easily and it is a fairly common problem
May 23, 2009 | Heating & Cooling
Rheem RGPH 07EAMGR keeps blowing 2A 250V fuse from transformer to circuit board. I can't find a short and the fan will come on for a 20 seconds then the fuse will blow again. i have done this 4 times(i had...
99% of the time proves to be a short- in the thermostat, furnace, condenser, or the 24V wires between them. Time to get out an ohm meter and check continuity between the wires and between each wire and ground - detective work - can be fun!?
Much less likely: condenser contactor, furnace control board, other condenser controls any of which could be drawing too much current. I bet on a short curcuit but if not I'd try changing the contactor first I think.
May 05, 2009 | Heating & Cooling
Weather King 10AJA3001AH Air Conditioner Logo
135 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
