Question about Bosch Washing Machines
Water not draining although spin still ok. Then went bang!
I noticed the problem last night when removing washed clothes from the machine - they were still wet although the spin cycle had seemed to work. I then put it on a spin only cycle and although it worked I could hear it clicking?? Today same thing happened and then it went bang and electricity went off. When I put it back on the washing machine did not respond.
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
Posted on Jun 01, 2009
Will not spin or drain tried unplug and lid switch is fine fill ok
Susan call your service repairman the warranty should cover the fix .
Dec 09, 2015 | Washing Machines
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 20422 leaves water and clothes soaked after spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Initial thoughts point to one of two places.
1. It's possible that your pump and/or hoses are clogged.
2. It is also possible that the "Motor coupler" between the motor and transmission is worn and cannot provide full power to the tub when agitating.
See the following illustrated descriptions of how to access the pump and motor coupler.
If either is bad or worn, they aren't all that expensive.
I doubt that the problem is the motor since the machine will agitate and spin.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=1c39a06ff50bcc5c8439ed37e02f402a
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Jan 06, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Does the wash but stalls before the last spin. help !
I have the same problem and have found (from this and other sites) that it's likely to be something stuck in the filter - check the access door and clear it. If the filter cap is stuck (as mine is) it's likely that there is something against the cap and advice is on this site for getting the blockage away from the cap. Search on "Bosch washing machine"
Jan 04, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer won't spin
Maybe when you were behind the machine, you did not refit the outlet pipe at the correct height; this is a height approx. 3 feet from the ground or more. Your pump pumps the water OVER this height.
You said it does not spin; you shd check out your outlet filter and clean it. If this is clogged the machine will not spin. All the best!
Nov 06, 2007 | Frigidaire GLTF1040A Front Load Washer
Washing Machines Logo
202 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
