Question about Canon PIXMA iP4600 Color InkJet Photo Printer
\i would like to replace in k tank but
Print head after openig paper output and top cover and pushing the power button only moving from right position to left and again back and dont stop for replacing ink tank ???
  • Canon Master
  • 5,568 Answers
It sounds like you are turning the power on after opening the covers.
My Pixma at least, centers the print carriage when the power is on and the covers then opened. Your printer doesn't understand what you want-
Posted on May 23, 2009
HOW CAN I REMOVE THE PRINT HEAD ASSEMBLY ON A CANON MX340?
Follow the given steps:
1. Confirm that the printer is powered on.
2. Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 12, 2012 | Canon PIXMA MP130 All-In-One InkJet...
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
I have a Canon printer PXMA IP6000 D. I suddenly will not print. I get a code, "Service Error 5200". I have tried turning it off and checking for a paper jam. Nothing works. Can you help me? Gary
1.Reset the printer
Follow these steps to reset the printer:Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
Turn the printer back on.
2.This is the waste ink reset proceedure and should clear the error (Waste ink absorber full [5B00] )
1. Power off printer2. Hold Resume button then press and hold POWER, the beeper will sound once.3. Keep holding POWER and release RESUME 4. Press RESUME twice, then release all buttons 5. When the indicator lights steady, press RESUME four times. The indicator should be orange. 6. Press Power to set data .
3. According to the service manual error 5200(LED alternateblinking in orange and green) indicates Print head temperature rise error ( The error means the print head is getting too hot.)
- Re-seat the print head
Confirm that the printer is powered on.Open the paper output tray and top cover.
Remove all ink tanks. >> click HERE <<
Raise the print head lock lever and remove the print head. >>Click HERE <<
Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard >> Click HERE <<
Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner. >>click HERE<<
Note: Check that each ink tank is installed in the correct position. >>click HERE<<
4.If the problem persists ,the print head may be defective and needs replacement .Here's a link to your service manual in case you need to confirm >>manual/hp/iP6000Dsm.pdf <<
Oct 15, 2011 | Canon Office Equipment & Supplies
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
How do I find and remove the printhead?
Here you go:
8. Close the inner cover and top cover. __________________
"If it's really a supercomputer, how come the bullets don't bounce off when I shoot it ?"
Jul 09, 2010 | Canon Office Equipment & Supplies
How can I remove the Canon iP3000 ink jet printed heads for cleaning?
heres the support site for that printer http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238 - downloads and drivers tab - has all the software and user manuals - the FAQ tab has a section on cleaning the printhead using software - also a link to removing the printhead
The FAQ has full images and step by step instructions Remove the print head iP3000
  3. Note: Gently open the paper output tray while holding it.
  4. After confirming that the print head holder has moved to the center, open the inner cover. Remove all ink tanks.
  9. Note: Check that each ink tank is installed in the correct position.
Apr 10, 2010 | Office Equipment & Supplies
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I cannot remove the printhead to install a new one , afrain of breaking somethin
1.Confirm that the printer is powered on.
Nov 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
57 people viewed this question
old marine
old marine
