Question about HP Officejet 5610 All-In-One InkJet Printer
Prinert prints fine then catches on top right hand side
My printer is working great except that it does not discharge the paper properly then prints a portion of the next page as a smudge at the bottom of the previous page. I must manually remove it page as soon as it is complete
  • 21 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd1
Posted on Sep 06, 2009
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Booklet layout
Is page on printing on the left hand side or right hand side?
<a href="http://stashbox.org/77137/printing.png">http://stashbox.org/77137/printing.png</a>
<img src="http://stashbox.org/77137/printing.png">
Jan 31, 2008 | Dell 922 All-In-One InkJet Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
HP LaserJet 3030 Paper is crushed from top right edge when printing/copying. How can/do I fix this? I have used a heaver weight paper and it does not get crsuhed, however the print is usually smudged right...
Try reseating your Ink Cartriges first then try printing to see if the error still appears, if it does try reinstalling your printer drivers... make sure you check your printer cables if they are conencted properly to your computer after reseating the cartriges.
May 21, 2010 | HP LaserJet 3030 All-In-One Printer
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Office Equipment & Supplies
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has...
The problem is that the metal paper stop is not fully recessing into the guide at the rear of the printer and the photo paper is catching on the lip on top of the stop. Take the back cover off the printer and check that the guide has not moved out of position. Also try to twist the photo paper tray to the left or right so the stop lines up better with the guide recess. This worked for my printer tempoarily, but then things went out of allignment again, so I took a slightly more drastic step. With only a single sheet of photo paper in the tray, print another photo. When the photo tray slides back to deliver the paper to the rollers, unplug the power cord from the rear of the printer to stop the tray from moving forward again. With a pair of needlenose pliers, bend the lip on top of the metal paper stop upward. This fixed my problem permanently.
Oct 19, 2009 | HP C7200-69016 Network Adapter
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Paper feed
What the hell, I have a mid-term that is due and I need this thing to work, What a piece of ****!
Jan 10, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Print Heads snagging paper
well if u have a straight paper - it´s the printers fault
ask for a replacement from the place of purchase or from the manufacturer
Dec 24, 2007 | Epson Stylus 1400 InkJet Photo Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
602 people viewed this question
Seeker5211
Seeker5211
