Question about Sony Cyber-Shot DSC-L1 Digital Camera
Sony dcr dvd110 handycam lens cover jammed open! Help
  • cleggmiester May 23, 2009
    Hi, sorry should have said before, the lens cover is a manual switch on this handycam. it seems to just be stuvk open without reason.
    thanks
  • Sony Master
  • 586 Answers
   According to the symptom the motor of the lens assembly starts malfunction therefore you have to replace lens assembly.
Thanks for using fixya.
Posted on May 23, 2009
When recording I get no image - only sound. Dont see image through the lens (lens cover is open). Have flashing message up top: E:61:11
This kind of problem occurs due to two possible failures, either ccd imager chip or jammed aperture in camera lens mechanism.
Turn On camcorder while looking in lens, you will notice aperture opens like an eye opens, if that happens that means aperture is working and ccd imager chip is bad, replacement of this chip will solve problem and local camera repair shop will do this job because camcorder will take apart and soldering work is required. Jammed aperture job is even more harder and qualified tech is required to do that.
Hope these info will help you.
Thanks.
Jan 17, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam dcr-dvd110 lense cover jammed open.
the camera should go to a repair shop immeadiately, the lense cap will be removed and replaced :)
May 23, 2009 | Video Cameras
"Remove Camera Lens Cover"
It seems bad ccd imager problem in Sony DCR-HC30E camcorder and ccd imager will be replaced.
Sony will replaced ccd imager free of cost as per announced scheme.
Click Sony CCD Imager Support UK for details.
Apr 11, 2009 | Sony Handycam DCR-HC30E Mini DV Digital...
Lens cover will not open
Let me know, If you have knowledge of how to open camera and do some mechanical work, I will provide you help.
Sep 24, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Lens Cover won't fully open
Hello Tomkimball, the solution for your problem is in replacing the lens barrier. Part number is 178727811. Best regards, Arpad
Oct 30, 2006 | Sony Handycam DCR-HC90 Mini DV Digital...
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Cyber-Shot DSC-L1 Digital Camera Logo
142 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
