Question about Cycling
I have a cigna ozark mtn bike. How do I get the front tire off??
See how to unscrew, but can figure out the trick to release the brakes to get the tire off?? Thanks!!
    President:
  • 1,138 Answers
Pull the two brake arms together at the top and you should be able to unclip the cable guide ( noodle ). The guide clips into the bracket on the arm opposite to the one the cable is bolted to. If you don't have enough clearance you will have to loosen or remove the brake pad on that side and adjust it again after. Hope this helps.
Posted on May 26, 2009
  • Michial Gueffroy May 26, 2009
    Try squeezing the two brake arms together at the top where the brake cable is attached. On the arm opposite to the arm that the cable attaches to is a bracket with a hole in it that the noodle clips into. The noodle is the part that the cable goes through on its way to the other brake arm. If there is not enough room to do this you will have to loosen one of the brake pads and slide it down to give you more clearance. You will have to readjust your brake pads after. Hope this helps.
Quick release bike tire installation
the pads don't need to be removed. Most brakes have a "quick release" on them. On linear pull brakes, use one hand to squeeze the two lever against the rim and with your other hand you can pull the "L" shaped cable noodle out the bracket and this releases the brakes. (you can also let the air out of the tire and install the wheel then reinflate the tire once you have it back on the bike). On road bikes with side-pull brakes most have a small lever you can flip up that activates a cam mechanism that opens the brakes up to allow the tire to pass through. Canti-lever brakes are similar to linear-pull brakes, just squeeze the brakes together and release the straddle cable. Hope this helps.
Aug 13, 2014 | Cycling
Rear brake not releasing
I'm assuming these are rim brakes and not disk brakes. A couple things can cause this, first check to make sure the wheel is true and the rim isn't rubbing on the brakes as it rotates. Next check that the brake pads are not hitting the tire when applied. If they are, then the brake pads need to be adjusted to contact only the rim. If they still aren't releasing then the brake cable could be corroded enough inside the brake cable housing that the spring in the brakes can't return it. drip a little bit of oil (TriFlow works great) on the cable where it enters and exits the housing and work the brakes. If this doesn't work then the brake calipers could have some corrosion on the canti-lever posts (assuming these are V type brakes common to a lot of mtn bikes), a little oil might get them moving again. If the bike is normally stored outside then most likely it's the cable corrosion.
Jun 11, 2014 | Huffy Men Mountain Bike (26")
I have a Schwinn Ditch mountain bike with front disc brakes and a quick release front tire. I pooped the tire off using the quick release on the hub and the tire simply slipped off and out of the disc...
You have to bleed the break fluid on your break and press the pads on both sides then insert the disc. When you bleed the break fluid do not press the lever.
Apr 10, 2011 | Schwinn Cycling
Cannot install front tire because the front brake calipers will not open up
With the tire not installed, push the brake calipers together and release the brake cable from one side, this should allow the calipers to spread fully. Now, install the wheel/tire into the calipers. Next, move the tire/wheel assembly around to get enough play to squeeze the calipers together and reinstall the cable in it's proper mounting location. Last, mount the wheel and tighten the axle.
Gary
Dec 26, 2010 | Pit SSR 110CC Pro Beginner Bike
What are the hardware differences between hybrid and mountain bicycles? How feasible is it to go from mountain (fat tire) to hybrid (thin low drag tire) functions? Can I just change the wheels or is it...
Some of this will depend mostly on what type of bike youre talkin' about here. Some cruiser/comfort type bikes will have the exact same rim size as nearly all mtn bikes and will swap with no problem but a 26 and 700 size wheel is NOT the same and there is NO compatibility between tires or frame of the bike including the fork. On a standard 26x2.1 size mtn tire the smallest you could go to is a 26x 1.50 that will fit on that wheel. if you have a French 26x1 3/8 size (S6) tire then the answer is the same....NOT compatible with anything 26" whatsoever. You cannot change the wheels either depending on the frame/fork you have. All you need to do is change the tires and keep the wheels! Any hardtail mtn bike will work fine as a commuter bike if you change the tires to a thinner and smoother tire for less rolling resistance.
Dec 16, 2010 | Cycling
I cant figure out how to put the front tire back on the bike
I assume you are referring to the brake cable. If so, there is a brake lever on each side of the wheel. The driveside lever (the left side as you stand in front of the bike) has a small hinged part with slot cut at one end. On the brake cable itself, there is a curved metal housing thru which the stranded cable runs and then is attached to the brake lever with a pinch bolt. You place this curved metal piece (called the noodle) in the hinged, slotted piece. Then the tension on the cable keeps it all together. You might want to look at sheldonbrown.com for a picture.
May 20, 2010 | Columbia Sportswear Columbia Trailhead...
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
May 13, 2010 | Victory VegasLow 26 Men's Dual-Suspension...
How do i attach front tire to frame?
if its quick release you pull out on the lever unscrew a little if you have too and then pop wheel out real quick ,,,to get back on you may have to unscrew it a bit more as the forks have expanded outward now, if its held in by nuts, you want an even amount of threads showing on each side, then you know it is tightened up correctly. but in both of these procedures make sure that you center the wheel between the brake pads evenly.
May 09, 2010 | Diamondback Lustre Two Women's Mountain...
Tire removal
depends on what kind of brakes you have cable or traditional cable compress them and the cable will come out traditional there is a bolt in the center loostn it and they will release
Jul 23, 2009 | Cycling
Cycling Logo
99 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
