Question about Dell ADA745 Computer Speakers
ADA745 speakers have no output
The 5 speaker system worked great for two years, then just stopped outputting any sound.  The sub powers up and the satellite speaker powers up but no sound.  I tried hooking them up to two other computers with the same result.  I opened the back of the sub to look at the circuit card and there were no obvious problems such as burnt areas on the board and the output drivers appeared to be ok.
  • 5 more comments
  • majpue Nov 04, 2007
    Same thing here; they just gave out after a long time of solid sound. It may help that the sound "faded" out on mine. Each day I had to turn it up a little more to get the same amount of sound. Eventually it was at 100% on the computer and speakers, and it faded to a whisper. Also, I can hear static when the speakers are turned up high, so they're obviously getting power, and can obviously output sound.
  • js3131 Nov 10, 2007
    Also had system 3 years with no problems. Failed suddenly. Speakers do not work on other pcs or other devices. Other speakers work fine on pc. Unplugged speakers and tested 3 of 4 with another device and they work fine. Only supwoofer/power supply seems to be broken.
    I contacted Altec Lansing and they confirmed subwoofer problem, not repair or replacement is available.
    This seems like it could be a single component in the subwoofer. Any advice on how to fix or service sources would be appreciated.
  • vbkkpr95 Nov 18, 2007
    Same speaker just stopped working ( 3 years leaving subwoofer on). The fuse looks good, but was going to change just to see. Thought I would search for answers first... here I am. I do hear a high pitched whine from one speaker? but have tried all avenues, except Dell. Figured I would know more then their book that is just like mine... Anyway, do I just purchase another set of speakers??? what is a good suggestion if I do need to just purchase new speakers? Thanks ahead of time...
  • Joel Downey Dec 28, 2007
    Same problem as others posted. Sound is beginning to fade. I have read that leaving the system on causes the power transformer to fail. I don't know if this is true, but I took mine apart a few months ago, and the power transformer was very hot. As it turns out, if I turned it off and let it cool back down, it started working again after power up. As a check, you can feel the four mounting screws on the bottom of the case. I noticed that the four bolts on the bottom of the sub woofer case (which are holding the power transformer in place) get hot enough to be mildly painful to touch due to being so warm.
    I am an electrical engineer, and if what I have read is true, I'm tempted to open it up, power it on and monitor the DC supplies as the unit warms up to see what happens. If the transformer output starts decreasing with time (as temperature hoes up), I guess that would confirm it. An option, if you have enough knowledge of how power supplies work, is to find an appropriate replacement transformer, or multiple transformers if you can't find one with multiple outputs. I don't remember how many outputs the transformer had, but I think it was more than one. I suppose I'll need to do the checkout and see what I can find out. If I need multiple transformers, then I'll need to rig up a custom mounting fixture to hold them.
    If I ever get around to it, I'll let you know what I come up with.
  • Anonymous Dec 29, 2007
    Back again.
    Well, this is a long story with a possible solution. I looked at the power supplies. They are OK. There is no transformer problem, at least with my unit. The issue I have is with the VCA (voltage controlled amplifier) on the amplifier board. There is a voltage signal which comes form the right front speaker, which controls the volume for all channels. The higher the DC voltage (up to 5.2 volts) the more volume. It appears as if there is not enough voltage at pin 10 and 8 of this I.C. You can find a data sheet here if you are interested.
    http://documentation.renesas.com/eng/pro...
    I'm only getting about 1.2 volts at the pin, and consequently not much volume. If I artificially increase the voltage, I get much more volume, like I would expect. I have checked out the components on the right front speaker PCB (Printed Circuit Board), and they are OK. There is only one component on the main PCB other than the two VCA ships, and it is a 1uF cap, which I removed to see if it was leaky. I found no increase in voltage, so the cap was not it. Something is loading the voltage signal going to the VCA chip. The only thing left on the PCB are the two I.C.s, so they must have a problem.
    A possible solution would be on the right front speaker PCB. There is a 33kohm resistor in series with the volume control potentiometer. I calculated the voltage one should get at the I.C. pin, with the values of the components on the right front speaker PCB, and it comes out to 5.3 volts maximum, which agrees with the IC spec. This assumes almost no load (current draw) at the VCA chip input. If I calculate the load at the I.C with the voltages I am seeing, I get something around 5kohm, which is way too low for the component values on the right front speaker PCB. (it also is way too low based on the I.C.'s internal schematic, so my assumption of an I.C. issue seems to be confirmed) I also measure the pin input resistance with the power off, and it shows about 4.5kohm.
    I tacked a 6.8kOhm resistor in parallel with R1 on the right front speaker PCB, and now I have the volume back. A minor problem with this approach is that the taper on the volume control has been altered some. The volume comes up much quicker than before, so be careful as you turn up the volume. I don't know how long that will work either. If the VCA chip continues to degrade, then the fix might only be temporary. Probably the "right" fix would be to replace both VCA chips on the board. However, that is a pretty intense task unless you are used to doing that kind of work, and have the proper equipment.
    If you have the same issue as what I had, here's how you can fix the problem. Disconnect the right front speaker from the sub woofer. Remove the two screws which attach the base of the speaker to the speaker housing. Remove the small screw under the base, found on the back of the housing. Next, you need to remove the grill. The grill is just pressed on, so you need to work a sharp object under the grill at the top and carefully pry it off. There are four screws holding the housing together. Remove them from the front. Once you have the housing apart, you can see the small PCB mounted to the front of the enclosure. Pull volume knob off the front of the enclosure. Remove the two screws holding it in place. Locate R1 on the front of the PCB. It should have four colored bands, orange, orange, orange and I think gold. (I'm doing this from memory, sorry!!) The others have grey bands, so don't use those. Now the work requires some minor skill. If you can solder, you are in good shape. I soldered the 6.8 kohm (6800 ohm) resistor on the "back" of the board, where all the copper traces are, connecting it to the same solder pads as R1. If you happen to get it across one of the other resistors, it won't hurt anything, but it won't work either. If you don't have a soldering iron, it might be possible to twist the leads of the new resistor around the leads of R1 on the top of the board. I think a 10kohm resistor would work well too, but I had the one I calculated would make it work like the original configuration so I used it.
    You can try things out before you put the speaker together, to see if this fixes the problem. Turn the RF speaker off, and plug it back into the sub woofer. Start an audio source, and turn the right front speaker back on, and slowly bring up the volume. If you are lucky, this will fix (at least for a while) the problem.
    Having figured this out, I still think the internal temperature in the sub woofer enclosure is too high. This might be what caused the VCA chips to degrade in the first place. While turning the volume control on the RF speaker does not "turn off" the speaker system, it does shut off most of the devices on the amplifier board. The main power supply voltage (rail to rail) is 35.3 volts with only the sub enclosure switch on. Turning on the Right front control reduces the rail to rail voltage to about 34.3 volts, and the transformer begins to heat up. I ran the unit this morning for about 20 minutes with just the sub powered, and the transformer did not heat up appreciably. After turning on the rest of the speakers, the power transformer temperature probably increased about 15 degrees C in 30 minutes. The temperature attained is really quite cool for a transformer, but inside the sub woofer enclosure, with no place for the heat to escape, it could get much warmer. At the least, I would turn off the right front speaker whenever you are not using the speaker system, especially at night if you turn off your PC. From what I saw this morning, that should keep things pretty cool. However, if you want to be absolutely sure you don't make things worse, turn off everything at the sub woofer switch.
    That's all I had. Hopefully this helps someone.
  • dcproduction May 29, 2008
    I was setting up new computer with these speakers. I heard the beginning of the windows login sound then it cut out and never heard a thing since. The microphone works and it shows the speakers work in the diagnostics but still no sound.
  • JamBox Sep 01, 2008
    My father gave me this system when i went off to school, when i got to school i plugged it in and wasn't working. all the speakers and subwoofer had power but there was no sound. it spontaneously started working again later in the year but was flaky and worked at a volume relatively low compared to other systems in the dorm. right now it's not working and i've been looking for an easy solution but haven't been able to find one.
Had the same issue as treefarmer and guest. Initially I thought that the voltage controlled pre-amps were the problem as well but further testing proved that wrong. If you remove the yellow wire from the RT Front speaker PCB and measure the voltage at the wiper of the pot it is still too low (should swing from 0 to 5 volts). On investigation it turned out that the pot was failing.
I couldn't find a proper replacement pot so had to fix the broken one. After removal and dissassembly it discovered there was a leakage path between the carbon trace and the bushing assembly. The top deck which contains the carbon path for the wiper can be removed by bending back the tabs that hold it to the metal case. Carefully cleared the shorting path with a probe and retested with an ohm meter..
Re-installed and wala it works!
Posted on Nov 04, 2010
Change main fuse but still not working right
First of all, nothing wrong with the fuse. A fuse is nothing but a short piece of wire with a resistance value. If the unit turns on, fuse is fine. The fact that the headphones you plugged in are working tells you that the music is finding it's way up to that point. You must realize that the speakers themselves have additional circuitry that the headphones don't use. If you could obtain a diagram for the circuitry you might find that a capacitor or a diode or a transistor got "zapped" when the high voltage was applied.
If you have this diagram and you don't know what component is defective, can you post that diagram and I would be glad to help!
Mar 02, 2014 | Bose Audio Players & Recorders
Adding Subs to a Bose 901 system
The Bose system has sound that is unmatched, the 901 with the equalizer is amazing. I have done what you are thinking of doing, the speaker runs 5ohms giving more power to the coils, adding a sub will color the sound and will not give the desired results, the 901 equalizer may be damaged with the modification of the sub, not recommended.
Mar 06, 2012 | Bose 901 VI Main / Stereo Speaker
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Problem w/ Panasonic SA-HT700 speakers
Try looking in the audio settings,it might be configured for stereo/mono or any number of surround sound settings e.g; 5:1, 7:1 In which case it might shut off the power to the circuit board inwhich the speakers are connected.If that fails .......Take it back!! Either the connection inside the speakers is faulty or the connections in the unit are faulty.
Oct 25, 2008 | Panasonic Home Theater System System
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Inifinity Entra Sub not working
The hum can be from the power supply not properly filtering, and or the output stage also has a short.
There is the chance that the speaker driver coil is now burned, or the power supply is now dead. If ther output stage is shorted and was putting DC on to the speaker cone, this will burn it very easily.
You should sent the unit out and have it serviced, unless you are properly trained, have the service and engineering manuals, and the test equipment to follow up on a proper repair and calibration.
Jerry G.
Apr 27, 2008 | Infinity PS-10 Subwoofer
Power LED blinking - no sound
Check windings on input and output of main power transformer.
Make shure no open windings.
Good Luck
Big Red
Oct 19, 2007 | Sony TA-N9000ES 5-Channel Amplifier
Dell ADA745 Computer Speakers Logo
956 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
