Question about Simmons Mattress Crib 'n More
Drop down gate bottom brackets broken
My wife went to put down the gate and it came off. The bottom plastic guides with the pegs on them have broken. They are the ones that attach to the bottm of the drop down gate. I need new ones.
    Problem Solver:
  • 10 Answers
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
customerservice@sjfdec.com
Here are the instructions for your crib. Please review them and see which parts you will need. We accept Visa or Master Card. Parts are non returnable. Delivery is normally 7-10 business days. We do have replacement parts for this crib. Please review the instructions and see what you will need. J Thank you, Cindy Customer Service Rep Simmons Juvenile Furniture ':Phone: 1-800-218-2741 ':Phone: 1-920-779-4004 7:Fax: 1-920-779-4216
Posted on Jun 01, 2009
I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
2 possible problems:
1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
Mar 24, 2014 | Samsung WA456DRHDWR 4.5 cu. ft....
How do you change the direction of the door opening.
(THIS IS A TWO PERSON JOB)(be sure u unload the door first)At the top of the door u have a bracket with three screws or bolts in it, take out the screws while the other person holds the door once this is done take off top bracket the door should lift off of the bottom bracket,now take the bracket off the bottom of the refrigerator,On the other side of the fridge there should be some small white plastic plugs pull them out ,this is were u will put the bottom bracket ,u will also have some plugs on the top of the fridge too..be sure u put the plugs back in the holes that u just took the screws out of.Put the bottom bracket on first,do not over tighten screws,then take ur door place the bottom of door on bottom bracket,put bracket for top of door in the top and screw back down now ur door should be good make sure it closes correctly,and of course put the stuff back in the fridge
Mar 31, 2011 | Refrigerators
How to I take apart the drop down side of this crib. I had it installed and can't figure it out
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
Jan 04, 2011 | Cara Mia Louise Crib
Replace rear tail light on ford focus wagon 2000
http://wiki.answers.com/Q/How_do_you_replace_the_tail_light_assembly_on_a_2000_Ford_Focus_SE_Station_Wagon
abar_a.gif?v=77611 Remove two screws and rotate to the side
To remove the rear light assembly for access to turn signals and brake lights:
1) Open the trunk to expose two screws.
2) Remove these two screws.
3) There are two brackets still holding the housing onto the car. Do NOT pull up and do NOT pull up on the housing; you will break the plastic pegs on the lamp housing.
4) Referring to the driver side lamp housing and facing the back of the car:
a) You can see these pegs and brackets on your left hand side if you pull the light housing GENTLY outward. The pegs are pointing into the vehicle from the left side of the car and stick into holes. There is also a spring bracket holding the housing on where the screws are.
b) To remove the housing from the brackets, push/pull the right side of the lamp housing outward and to the left. Do this carefully so that you do not break any of the plastic pegs. What you are looking to do is detach the housing from the spring bracket, and then push/pull the pegs from their holes. You are simply rotating the lamp housing out of the brackets.
Simply mirror instructions for removal of passenger side housing.
Replacement:
This part is a little easier. Line the pegs up with the holes, and then push gently to line up spring bracket with it's hole. Then, push with a little force to get the spring in the hole. Make sure the pegs are in their holes or else it will be crooked and loose.
Take your time! You do not want to break the plastic. It should eventually come loose. With any plastic on your vehicle, be careful not to force it. Good luck!
Read more: http://wiki.answers.com/Q/How_do_you_replace_the_tail_light_assembly_on_a_2000_Ford_Focus_SE_Station_Wagon#ixzz197C2shUn
Dec 25, 2010 | 2000 Ford Focus
Stearing wheel horn assembly wire to th stearing colum is disconnected
The wire on the steering wheel should have a plastic peg on it. The column where the wire goes should have a notch for the peg to turn into. If one of these is broke they will not stay together.
Sep 22, 2010 | 1993 Chevrolet S-10 Blazer
Will not go on
Assuming it's not a dead battery or a failed unit:
If nothing happens at all when you push the button on the Blackout Buster, it may be due to the plastic lever used to translate the up/down push button to the sideways action needed for the on-off switch.
At the front of the unit take a flat blade screwdriver and slide it under the opening at the bottom, and push straight up to disengage the latching tab.
The bottom will be released and you can lift the front plate up, unhooking it from the top.
Check the grey plastic lever that should be in the groove of the push button, if it's missing, you'll have to see if you can find the broken piece inside the unit. If you can hear it rattling around, you might be able to shake it out the opening in the front. Otherwise you'll have to open it up by unscrewing it to find it. A single screw holds the lever on the pivot peg.
You may be able to epoxy it back together to get it working. The LED light guide obstructs the lever from sliding onto the pivot peg when it's intact, but you can carefully flex it away to get clearance to slide it back on.
Check that the sliding button moves the lever left and right after putting it back in the groove. Put the front plate back on by hooking it at the top, then pushing in the bottom until it snaps in place.
Mar 05, 2010 | PK Nextgrid BlackoutBuster B6U2 UPS System
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Apr 20, 2009 | Garmin GPS 12XL GPS Receiver
How do I replace the battery and where is it located?
Procedure:
Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
The battery terminals are removed with the 10mm wrench
The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
Gently lift the battery out while holding the cables out of the way.
Tools required:
10mm wrench, small flat screwdriver
Procedure:
Tools required:
Procedure:
Tools required:
Procedure:
Apr 17, 2009 | 2004 Nissan 350Z
2001 oldsmobile alero window off track,
first remove the door panel there are three screws that need to be removed first 2 under the inside door handle and 1 on the lower left hand side behind a reflector then pull off the panel it will be held on by push clips, once inside move the plastic weather bearrer to the side ,run the window half way down you should see 2 window holding brackets pull the window up so you can drop it in the brackets, first get some black window adhesive fill the brackets with adhesive put window in brackets and roll it up and leave it up for 24 hrs.If the brackets are broken you will have to replace the whole window motor assemly which you can get on line for 89.00 not the 250.00 at dealer and you can install it yourself its easy to do.
Jan 22, 2009 | 2001 Oldsmobile Alero
Simmons Mattress Crib 'n More Logo
326 people viewed this question
Top Simmons Mattress Baby Gear Experts
Stan Skaggs
Stan Skaggs
Glen Weitzdoerfer
Tom Chichester
Are you a Simmons Mattress Baby Gear Expert? Answer questions, earn points and help others
