Question about Craftsman Gas Mini - Tiller/Edger
Roto tiller won't start - primer bulb
Craftsman 4 cycle mini tiller was working fine then, overnight, it would start rough and then stall out when moving to position 3 on choke (air open thru filter). Filter was soaked in gas and oil. Cleaned and replaced, but now won't start. What I noticed is that primer bulb does not pop back out (remains depressed), so I can't prime with 10 pushes. (Hope this makes sense). Any suggestions? Thanks
  • 376 Answers
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
Posted on May 23, 2009
I need the primer bulb and fuel lines that have rotted out
Go to sears and pick them up,they are waiting on you.
Aug 08, 2015 | Craftsman 2-Cycle Mini Tiller
Start mini tiller without primer bulb
Not sure if you can. It is much easier if you install the right primer bulb. Those units are made to have primers to be used I believe. if there is a place for a primer it needs one.
Jul 10, 2014 | Craftsman Gas Mini - Tiller/Edger
Why will the plastic primer area will not fill up?
One reason that the primer bulb will not will with fuel, besides having no fuel in the tank, can be that the two fuel lines have been reversed. If you pulled the fuel lines off for some reason then switch their positions and see if that makes a difference when you push the bulb. You should see fuel moving back into the fuel tank.
Jun 22, 2014 | Craftsman 2-Cycle Mini Tiller
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
How do you change the primer bulb in a craftsman mini tiller?
some primer bulbs come as an assembly and have two clips that snap into the housing others are bolted in with 2 screws if so remove the screws and make sure to take what is left of bulb to match up the new one
Oct 15, 2012 | Craftsman 2-Cycle Mini Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
How to change primer blub on craftsman mini tiller?
I suppose this is on the 4-stroke mini tiller. There is a circular retaining washer with "tangs" on it in the bulb housing area. Clean the area well and you will see it. It is black probably. Use a very small screwdriver and reach in and pry it out in a few different spots and it will pull free and so will the bulb. Insert the new bulb and the the retaining washer making sure the tangs on it are all nice and flat. Press it back into place with the same small screwdriver being very careful not to puncture or tear the new bulb.
Nov 07, 2010 | Craftsman Gas Mini - Tiller/Edger
I have a honda FG-100 It has a new carb on it but the primer bulb will not prime. blows bubbles back in the take but wont **** gas.
This happens all the time. The hoses leading to the primer bulb are on backwards.
Switch them and you'll be fine
Mike
May 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Craftsman 2.5 hp edger stalls
it sounds like the the carb. either it needs cleaned of the float inside isnt working i would say to just get a new carb. if its possible concidering the age but try to clean the filter first im sure it has one sry but thats all i can think of
Jun 06, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman Gas Mini - Tiller/Edger Logo
1,127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
