Question about HP Officejet 5610 All-In-One InkJet Printer
Aligning cartridges, please wait
Been trying to fix this issue. HP can't help, the tech had me #3 and #6.
When I turn my printer on, it wants to aligning the cartridges. It prints the page, I put the page on the glass, then it says aligning cartridges, please wait. I have left it for the last four days, it still says aligning cartridges. There is nothing wrong with the ink cartridges because I put them in my other printer and they are fine and full. Why is it stuck? I have unpluged and repluged. I really like this printer, please help.
    President:
  • HP Master
  • 1,996 Answers
Pressed ok more than once to start alignment??
Have you worked through this page already? And you tried the "Bypassing the print cartridge alignment" solution? See HP's solution here. Make sure you don't have photo paper or colored paper in the input tray when aligning...
When you perform the reset, did you unplug the data cable (usb) as well as the power, and wait a few minutes? Try leaving both data and power cables unplugged for 1/2 hour and then resetting, and make sure you complete the power cycle by pressing start copy color. Link here.
If none of these steps work, try removing and reinstalling the cartridges, and if that doesn't help, here's a last ditch fix that may work in your case.
Otherwise, I'm afraid service is the answer...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 23, 2009
Printer preparation please wait error message on HP 6500 printer
This problem happens when the cartridges are not properly aligned. With the printer turned on, open the cartridge access door. The carriage will move and then stop. Now uninstall the cartridges from the holder. Clean the electrical contacts on the holder and then reinstall the cartridges. Make sure the cartridges are perfectly placed into the holder. Close the cartridge access door. Turn off the printer and now turn it on. Check if the printer says Aligning cartridges. If this is not working, then hard reset your printer. With your printer turned on, unplug the power cord from the printer and the wall outlet. Wait for a few minutes and reconnect the power cord. The printer should turn on automatically. If it does not, then press and hold the power button to turn it on. Resetting the printer will fix most issues dealt with the printer.
123 HP COM Setup Printer Quick Setup and Install Support
May 29, 2012 | HP Officejet 6500 Wireless All-in-One...
Hp photosmart c5280 Cartridge Alignment problem. everytime I try to print it tells me to run alignment test, and then when the alignment is off, it won't let me print...HELP!
Please follow the below steps. After evry step, if the cartridges are not allign automatically, allign it manually by the below steps.
To align the cartridges from the All-in-One
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Then scroll using the down arrow key and select Tools then select Align print cartridge or Align printer.
STEP 1.
Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Apr 28, 2010 | HP Photosmart C5280 Printer
Print cartridge alignment failed. What does this mean and how do I fix it?
2. Press Setup.
STEP 1.
STEP 2.
STEP 3.
Apr 28, 2010 | HP Photosmart C5280 InkJet Printer
Printer not aligning after changing cartridge
Once you insert the cartridges, please follow the below steps.
1. Press the Setup button on the control panel.
2. Press the number 6 on the keypad or scroll to Tools.
3. Press 4 on the keypad or scroll to Align Printer. The alignment process starts.
If still the issue is not fixed, please follow the below steps.
STEP 1.
STEP 2.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Apr 18, 2010 | HP Officejet Pro L7680 All-In-One Printer
Print cartridge will not align
This could be an issue from remanufacturing. Try a new cartridge from HP.
Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
I wish that I could be of more help.
Feb 18, 2010 | HP PSC 2110 Color Printer
Printer will not align
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | HP PSC 750 All-In-One InkJet Printer
HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Mar 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
Nov 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Alignment of cartridges
Please click on the web link given below and perform the steps as provided in the web page to get the issue fixed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042820&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Jan 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp 1350 psc alignment page
OOh dear your printer has a little confusion gnome!!!, i am assuming it is attatched to pc, you have to start by resetting it. Take out the cartridge. Close printer and turn it off. Unplug it, remove all cables. Now, take 3 deep breaths, replug all cables, turn it on and wait for pc to recognise it. It will reset it for you. Now, try printing normally again. Re-post if this does not fix it.
Aug 28, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
2,413 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
