Question about Maytag MSD2732GR Side by Side Refrigerator
Freezer Thaws every few days
I have a Maytag MSD2732GR Side by Side. Every few days the freezer thaws out and then it will freeze again. The refrig side seems fine. This has happened several times. I would like to figure out what part is causing this so I can replace it. Thanks in advance for any help.
  • 4 more comments
  • jm6734 May 23, 2009
    It is about 3 years old. I put a thermometer in the Freezer and when it seems to be working it is at 10 degrees. I guess I don't know for sure that the Refrige side is keeping the right temp other than I have seen no signs that it is not. When the Freezer got up to 40 degrees, the Refidge side seemed to be normal. Thank you for you help I can provide any other information you need.
    No frost is building up, ice does form in spots where there were small pools of water (on top of boxed items, etc) after it starts working again.
  • Anonymous May 24, 2009
    Yes it runs, just not cold. I ordered a defrost timer and a relay (because I found them both fairly cheap) think that might solve it? Again, thank you very much for your help.
  • NorseXNW
    NorseXNW May 11, 2010
    So do you hear it running at all when it goes nto this thaw mode? Any noise from the unit at all?
  • NorseXNW
    Is there frost build up inside the unit?
  • NorseXNW
    When you say the freezer thaws out but the fridge is fine how can you tell what are the actual temperatures in both? Does the temperature rise in the fridge as the freezer thaws? How old is the unit?
    Problem Solver:
  • 6 Answers
It sounds as if the defrost timer could be going bad
Posted on May 23, 2009
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Roper refrig/freezer freezes for short time then thaws
try the cold control and or the defrost timer
Jan 28, 2010 | Whirlpool Freezers
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Refr/freezer alternately gets too cold and thaws
My first thought: defrost timer which shuts off the compressor and turns on a heater in the freezer is sluggish.  I'd change it out.
Nov 15, 2008 | Amana Refrigerators
Freezer melts then freezes again
hi thanks for the question is this a new fridge . if it is the fridge does shut down to enable the freezer to thaw. if it did not do that do that the freezer would ice up . not cooling the fridge part thanks for the question
Sep 28, 2008 | Kenmore Stainless Steel Compact...
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
sounds like a defrost or sensor problem. or the main P.C.board. probably the board and sensors.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Jul 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2732GR Side by Side Refrigerator Logo
202 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
