Question about Dell Latitude D610 Notebook
Black and white lines after bios screen before boot up
When my laptop boots, after the bios screen i'm left with a black screen with black and white lines at the bottom with a solid white line moving slowly accross them similar to an install process.This takes a while then our windows welcome screen appears and all is fine from then on. But when i reboot the same thing happens.Can anyone help me please?
  • 2 more comments
  • Anonymous May 25, 2009
    PatKam_AU
    I don't think i'm replying properly here (novice to threads). I can't see a reply box. But Anyway
    Thankyou for your reply.
    I am using Win XP Pro and this does not seem to be normal. This never happened in the time that i have owned the notebook. Only started happening since a complete format and reinstall of XP.
  • v8mycareer May 25, 2009
    PatKam_AU
    Guest reply was mine, sorry. Had to log in Daaa.lol
    as i said in guest post
    Dageezer,
    Systems does boot into windows eventually, but not after 5 or minutes. This is not normal for XP or for me.
    I have updated the bios direct from the dell website for this laptop and i have downloaded and installed a driver for the graphics card RadeonX300.
    This hasn't fixed the prob for me.
    I was told tjhis could be a hard drive problem and did a hdd using win chkdsk. Results were fine. But then dowloaded a toshiba hard drive utility (cause it's a toshiba drive) and this utility could not even find a hdd connected to my laptop. Wierd and frustrated.
    Try booting up to show a presentation infront of clients!!!!
  • Patrick Kam May 11, 2010
    It seems like you are using Windows 95/98/Me/2000 (Can't remember what it looks like now)? These black and white lines (blocks?) represents the progress bar as seen in Windows XP. It's normal isn't it?
  • 3,940 Answers
The issue appears to be cosmetic if the system boots to WIndows and there are no display issues using the system. Some systems I've seen have a bit of video distortion between the BIOS splash screen and the desktop. A couple things may change that. Update the system BIOS and the video driver to the most current available
Posted on May 23, 2009
  • IQUIT May 25, 2009
    OK, the details you provided are helpful. Since the issue started after the reinstall of XP, then it may be that all the drivers were not loaded in the correct order.
    The correct order for driver installation is as follows:
    Notebook System Software
    Chipset
    Video
    Audio
    Network
    Wireless
    Modem
    Touchpad
    If the drivers were not installed in this order, then It MAY be part of the problem.
    A video issue of 5 minutes during boot is abnormal. If drivers were not loaded in that order, you might try another install of XP and driver install in that order.
    Scholar:
  • 88 Answers
Workaround: Try a descriptive mode of booting XP - Add the option " /SOS" at the end of the %systemdrive%\boot.ini for a dos-like bootup showing what's being loaded instead of the graphical progress bar. black and white lines after bios screen before boo - 0b0f526.jpg
You'll need to modify it with Local Administrator account.
Posted on May 25, 2009
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
My laptop screen turned white all by itself while running. I turned it off. Now, when I start the laptop it displays the same white screen after the boot. The white screen is stripped with blue, black and...
Hi there, most likely there is a problem with either the GPU of your laptop.
The only other troubleshooting step you can try is to open the laptop up and reseat the connector of the LCD to the motherboard where your GPU is integrated.
You may also want to try an external monitor and if nothing is displayed or the same screen is displayed then the GPU of your laptop is fried and it needs to be replaced.
Hope this helps!
Sep 11, 2011 | Computers & Internet
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Black screen with a little white line in top left corner. wont boot in any mode
that in fact is called the "prompt" or "cursor prompt" sounds like you havent got an operating system,Try F2 whilst booting to go into bios pages to configure boot sequence.Navigate with "tab" and arrow keys,,,save an exit ,,or restore to factory defaults etc--good luck!
Davey Snake!
Oct 25, 2010 | Compaq Computers & Internet
I have an acer laptop and every time I put it on the acer logo comes up but then it just goes black with a flashing white line on the left hand cornor. How can I fix this?
you have a damage operating system or your laptop is to slow to to find your booting system kindly be paitient to wait im sure at a certain time it will flash some error or it will boot but if you know in what drive is your operating system is installed, go to bios settings of your laptop and set it to first boot.
Oct 13, 2010 | Computers & Internet
My laptop Preasario cq61 has the black screen problem, when it starts it shows the first screen fine ( the one where you can hit ESC to enter the bios) after that it goes black and in the top left corner...
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
Apr 11, 2010 | Compaq Presario Notebook
Blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
May 08, 2009 | Toshiba Satellite A105-S4384 Notebook
Toshiba a75 s-206 cuts on than idk!!!!helpppppp!!!!!!!!!
If you put in a Windows CD does it boot into the cd menu?, does the black screen have the blinking white line at the top left corner?
Mar 05, 2009 | Toshiba Satellite A75-S206 Notebook
Dell Latitude D610 Notebook Logo
2,747 people viewed this question
Alun Cox
