Tip & How-To about Samsung SGH-R225m Phone
This happens when the first installation of the software had not been successful .
What usually happens is that wrong system registry cannot be deleted
when uninstalling software, or overwritten when reinstalling, therefore
uninstalling and reinstalling the software does not fix the problem.
A bad setup happens often because you connect the USB data cable before
installing the software, The firewall or security software had not been
disabled, when you are asked if to allow a change to system during
setup and you deny, when your account does not have administrator
privileges, or when Windows has a problem.
What you can do is the following:
Unplug the USB cable.
Uninstall the software.
Do a system restore to a date before installing software for the first time.
Disable antivirus, firewall and security software.
Install again the software. Start software setup with USB cable unplugged.
On Vista, to start the setup, locate the installer file (eg. setup.exe
or install.exe) and instead of using double click to run the file,
click the right button of mouse and chose "Run as Administrator" from
the dropdown menu.
Ensure that you always allow changes when asked by the system.
Connect USB data cable with device on when asked.
If that does not work, then Windows has a problem, in that case you may need to reinstall windows.
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
