Question about Huffy Cycling
Need replacement rear wheels for 2 x grren machine 2. Can you help?Karen
Need replacement wheels for 2 x green machine 2. Can you help? Karen begg
Power outrage, now we only get flashing grren light. I have tried reset, power directly to outlet, after about 5 minutes ight will sto flashing for about 2 seconds then back to flashing. Please help
Replace the DM capacitors. Very common problem. The WS55859 DM repair kit available from www.tvrepairworld.com is the correct kit for your model also, and the kit contains the caps and the CD with repair instructions.
Jun 22, 2011 | Mitsubishi WS-65869 65" Rear Projection...
Wheel is missing letters, broke off I guess. Does the wheel get old and fall apart? I haven't used the type writer in a few months. Should I get another wheel or call for repair? Thanks! Karen
The wheel usually last for many years. I'm assuming you are getting 2 vert lines in place of the missing letter (hammer face). Used replacement wheels are available for 29,95.
DickyO
Cleveland Business Machines
216-241-0027
Jan 31, 2011 | IBM Wheelwriter 6 Typewriter
What color are the speaker wires
two purples two greys two whites and two green wires. I believe the grey and whites are front speakers and the grren and purple are rear. Cant remember which one is right or left.
Jan 10, 2011 | Pioneer DEH-P6800MP CD Player
I have a narrow green band across the top of the screen similar to a rainbow -also Ex: most of what appears on the screen is double vision. thankyou.karen t.v. is approximately 8 years old
Your TV needs the convergence ICs replaced .
Not something you can do, techs usually charge about $300-$400 to replace them in your house.
I may be worth fixing if you can find a reliable tech in your area.
best of luck
Dec 17, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Won't power on
hello,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 25, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv will not turn on
Common problem with this set are the two 1000uF@25v capacitors and the 150uF@400v cap on the power supply board.
May 12, 2009 | Apex Digital LD1919 19 in. LCD TV
MOT Test
a) Sitting on machine check:1. All controls switches and horn 2. Front suspension forks handlebars and head bearings. b) At the front of the machine check: 1. Front lights and indicators 2. Front brake master cylinder (if fitted) c) Place the machine on its stand and raise front wheel check: 1. Steering, front forks and head bearings 2. Front brake and wheel bearings 3. Wheel and tyre condition. d) Lower front wheel and go to right side of vehicle and check: 1. Frame, VIN, seat and foot rest 2. Exhaust system 3. Final drive (if fitted to RHS of machine) 4. Rear wheel, tyre and brake e) Raise the rear wheel and check: 1. Rear wheel, rear brake/components and tyre condition. 2. Rear suspension and final drive f) At the rear check: 1. Rear position lamp(s)/stop lamp(s)/reflectors and indicators. 2. Rear suspension. 3. Registration Plate g) On the left of the machine check: 1. Frame and foot rest 2. Exhaust system 3. Final drive (if fitted to LHS of machine) 4. Rear wheel, tyre and brake. h) At the front of the machine check: 1. Wheel alignment 2. Headlamp aim 3. Brake performance,,,
Nov 10, 2008 | 2003 Hyosung GT 600 Comet
Green blinking light
The DM module in the TV is bad. Some can be fixed easily some cannot. What is the model #?
Sep 11, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
Blue screen
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Aug 12, 2006 | Samsung HCN4226W 42" Rear Projection...
Cycling Logo
166 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
