Question about Garden
Yard Machine posessed by devil
I broke the belt for the blades and replaced in. I had to drop the deck to get the belt on. Not 10 mns later I was mowing and felt a jolt in the machine and now when I turn the key the motor sounds different. I sounds like something isn't catching, kind of like it's loosely free spinning, almost like another belt broke somewhere.
This is my first rider, I don't know about repairing them, never had the opportunity. I took out the spark plug and it looks kind of bad, but I don't know if a bad plug will just stop the rider mid mowing.
HELP! I think my rider is posessed!
  • 7 more comments
  • lordazzo13 May 23, 2009
    Hi longhorn294!
    Yes it spins for a couple secs and comes to a full stop.
    When I put my hand flat on the screen and turn there is resistance, but I can still turn it. It turns but then in a sec comes to a stop. It does not spin freely, it resists my attempt to spin and comes to a stop a couple inches later.
  • lordazzo13 May 24, 2009
    Well, it does not spin freely and evenly like a top.
    If I turn the engine it starts to move but there is resistance about every revolution, not steadily worsening, just the same.
    If I spin it by turning it with my hand it will stop itself, but if I go to spin it again it's the exact same scenario. I'm sorry if I can't describe it well.
    Also, while I was mowing I heard a thump and I thought I ran over something, when I went to restart it reeved without turning over. Just a continual spinning noise without that sound where you know it's gonna start eventually.
  • COUGHY_MAN May 11, 2010
    Does the mower have a Kohler engine on it?
  • Dwain Pippen May 11, 2010
    Well, without being able to actually see it myself, it's hard to put a finger on what has happened. It could be a number of things from a broken rod to a failure in the valve train, etc. My best suggestion is to take it to a good shop and have it checked out. It my prove to be something minor. That;'s about all the help I can give you like this. Sorry, wish I had a solution for you. Dwain
    Ok. What I'm asking is if you feel any resistance while turning the engine by hand through a couple of revolutions. Does it feel the same all the way around or is there a spot every revolution that it get harder to turn from compression. I'm trying to determine if your rod is still attached to the crank or not.
    One more question... Can you put your hand on the screen and turn the engine freely without feeling any resistance through at least a couple of revolutions?
    If you open the hood and watch the engine turn as you crank it, does it spin fast and when you release the key, does it keep spinning for a couple of seconds?
    Sergeant:
    Champion:
  • 226 Answers
There are to belts the lower belt drives the blades ,the belt above it drives the mower that's mabey where your problem is.
Posted on Jun 06, 2009
How to tighten yard machine riding mower deck belt
indicates incorrect "V" belt used as replacement
The belt should be just proud of the edge of the pullies
If there are steps in the grooves of the pulleys they they need replacing
the adjustment is by a spring loaded idler pulley
Apr 28, 2018 | Garden
Mtd yard machine transmission
look under the mower and see if the drive belt has come off of any pulleys. sometimes they will have a stick get in there and the belt will come off and it wont move. also be sure it hasn't broke.
Nov 24, 2017 | Garden
Yardman
under the deck ether running backwards are forwards depending what drive your useing but all under deck you might have to dig thrugh the grass but its there unless it broke then look for the pully on the blade shaft
May 27, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Need a deck belt diagram for MTD 13AL452F120525197-115
I also need a deck belt diagram because a manual didn't come with my 746 SRL yard machine
May 12, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
My lt1000 craftsman riding mower belt broke. I bought a new one and can not seem to find the manual to see how to replace it. Can you show me a diagram please?
On your mower, lift up the seat and you will find a silver sticker with numbers on it. There is a 9 or 10 digit model number. It will look like 123.456789 Go to www.searspartsdirect.com and input your model number and perform a "model" search. I am assuming that the belt you are referring to is the deck belt. Go to the deck section and you will see a basic pattern of what shape the belt will have when installed. There are 2 kinds of pulleys on your deck...V-groove & flat side. The v-groove pulleys go on the inside of the belt, the flat side will go on the outside of the belt.
If the mower is more than 3 or 4 years, it is probably a good idea to replace the drive belt(s) also.
Good luck.
Oct 22, 2010 | Craftsman Replacement Belt for 42" Deck
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Installing blade belt
you have to raise the mower then drop the rear of the deck by removing the 2 pins on the blade adjustment lever.once you do that it should go pretty easy
May 17, 2009 | Mtd Garden
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
