Question about Adapters.com GrabBeeX+ (GRBX1)
Can't run GrabBee
When I start running GrabBee it shows an error window saying: "No Skin On yor system!" Any idea how to resolve the problem?
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
Screen says boot path error and to check man. manual
salazar13gru,
You will need to boot to the Windows Disk and run a repair install to resolve this error. If that does not resolve the error you will need to format and reinstall Windows. Follow the steps below to run a Repair Install.
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 02, 2013 | Dell Dimension 8200 PC Desktop
When start system show error
Does the system boot up? This does not seem like an error that would stop it from booting up, just an annoyance.
Click Start/Programs and look for the RUNcommand. You might see it anywhere once you click Programs, or it might beinside the Accessories folder. Click RUN and when it opens up type"msconfig.exe" (without the quotes) then hit ok.
When the System Configuration window opens click the Startup tab. In theStartup Tab we are only concerned with 2 columns, the first column which is theStartup Items and the column that says Command. You can put your mouse pointerbetween two column headings and it will turn into a +, then hold the left mousebutton and drag the column over to the right to expand it so you can readwhat's below it.
Now everything has a check mark beside it. This means that everytime youstart your computer, these items have to load and run.
Start with the first item listed under the startup item column and look at itand look at the command for it. We want to find the command that your system is having a problem with the script file. The command is C:\WINDOWS\system32\FAantivirus.vbs. When you see it under the command column take the check mark off over to the left next to the item column and this will keep it from running the next time you boot your system.
May 07, 2012 | HP Desktop Computers - Hewlett-Packard...
My ata 40 gig hdd after installing xp on aformatted drive.every time i run chkdsk it says i have problems that chkdsk can fix,but never dos.
Click start and run
type cmd and press enter
type the following line replacing z with your yor har drive letter
chkdsk z: /f/r/x
you should get a message saying it will check on the next system restart, say Y, then restart your system
When it boots up just before it goes into windows it will check and repair.
Sep 21, 2010 | Computers & Internet
My hard drive got unplugged without being stopped and now keeps running into read errors
Hopefully, the read errors are not from physical damage.
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and both checkboxes,both 'fix file system errors', and "scan for and attempt recovery of bad sectors" then click ok, the computer will then tell you it will scan upon next reboot (which upon reboot will take about an hour). Now click the DEFRAG NOW button. then choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to format the hard drive and reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Apr 26, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My hp dv 9000 pavilion shows blank screen with cursor how do I fix this
3. Defrag
4. Scandisk
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
Good luck.
James.
Apr 25, 2010 | HP Pavilion dv9000z Notebook
Error 105
It's possible that you have some kind of malware issue. I would download and run Malwarebytes from here. Update the definitions and run a quick scan to see if it finds anything. It would be best to do this from Safe Mode to make sure nothing else is running. Also would be good to test if this happens in Safe Mode as well. I would recommend booting up into Safe Mode with Networking so you can still get on the internet.
To boot into Safe Mode, Restart your computer and keep tapping F8 usually right before the Windows XP screen appears. If you see the Windows XP screen then you have gone too far.
The other solution would be if you have a corrupted operating system. At this point I would just backup your data and reformat you PC to start out fresh.
Jul 30, 2009 | Microsoft Windows XP Media Center Edition...
RUNDLL
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll
Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below:
1. Open your Start menu.
2. Click Run
3. In the command screen type:services.msc
4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service.
5.Stop the "dll"service immediately.
STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start
2. Click Run
3. Type regedit
4. Find this registry key:
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]"
6. Delete the value and Restart.
May 01, 2009 | Computers & Internet
Error when installing Move data process :-132
try to use another grabbee i think there's something wrong with the connection... that's why it display an error message..
Apr 28, 2009 | Computers & Internet
Windows host process(rundII32)has stopped working.
if you have the origial os xp system disk try doing a repair instal rundel is a windows system file but be careful to follow the on screen instructions or you could lose yor stuff and end up with a brand new inserlation
Jul 22, 2008 | Computers & Internet
Televison & Video Logo
221 people viewed this question
Top Adapters.com Televison & Video Experts
Electro Med Services...
Are you an Adapters.com Televison and Video Expert? Answer questions, earn points and help others
