Question about RCA Audio Players & Recorders
Tonearm goes to record and returns to start position without ever playing the record
Tonearm travels to record and immediately returns to start position without playing the record.
  • 104 Answers
Do you have an adjustable piece at the end nearest the pivot point [the bit that goes into the turntable] if you do then adjust the weight so there is more downward pressure on the record [ or just try putting weight on the tonearm ] and see if this helps
Posted on May 23, 2009
Sony PS-LX55II Tonearm Doesn't move when playing
Is there an antiskate or skew adjustment and also a way to set that counter weight? If any of those are wong then it wont work
May 11, 2013 | Sony PS-LX250H Turntable
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
Arm will not travel all the way across record before it lifts
Tonearm wiring is tangled under tonearm. Cheers john, Stylus City.
Sep 22, 2011 | Thorens TD295-MKIVB Turntable
Turntable stops before the end of a 45. Works fine for Albums. I found 1 solution but that says to take the player apart.
Just had this occur to me and after a couple seconds figured it out. Tonearm returns once it hits a certain height on the tonearm guide (the bit that goes up and down when you raise or lower the tonearm cue lever.) If you manually hold down the guide, the tonearm will continue to play the 7" until the end. You don't have to push down hard, just a nice gentle [pressure while the record plays should do it. It solved the problem for me.
Apr 23, 2011 | Crosley 0187SST Turntable
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
Dual 1218
What happens if you lift the tonearm and slowly move it over its travel in toward the label area past the expected point at which it should cycle? There should be a mechanical click as it engages the lift / return cycle. If so, the mechanism works but might be out of adjustment due to wear and tear.
Perhaps cycling the Record Size switch a few times might have a positive effect on the function. There doesn't seem to be a user adjustment for the end of play cycle.
You can get the manual for free after you register at:
http://www.vinylengine.com/library/dual/1218.shtml
If you decide to venture into the mechanics be cautious, always protect the tonearm from damage and make sure you rotate the platter only clockwise as there are mechanical interlocks that could get damaged if you turn it the wrong way.
Mar 09, 2010 | Technics SL-1200 Turntable
Turntable stylus not staying on record
Since there are no tonearm adjustments the only solution in the manual that comes close is to make sure the turntable is level. The other possibility is the no-brainer of checking the stylus cover is NOT rotated down, preventing the stylus from contacting the record.
A quick and dirty test of tonearm balance being too light would be to unplug the power and manually move the tonearm over the platter. Gently lower it to see if it floats in the air or lightly but firmly contacts the platter. That won't tell you if it is tracking properly but it might indicate or eliminate tracking force as the culprit.
Apr 26, 2009 | Audio Players & Recorders
Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Jan 21, 2009 | Audio Players & Recorders
The spin of the tonearme doesn't works softly.
hex screw hole under the tonearm you have to seperate the tonearm from sitting on the base, then tighten back down homie
Oct 20, 2007 | Vestax PDX-2300 Turntable
234 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
