Question about Averatec 3200 Notebook
Averatec 3200 PC is too hot and noisy
Every time I turn my computer on after about 30 seconds it sounds like  a vacuum cleaner running. This is so embarrassing.  I've had other laptops and my husband's laptop doesn't make all this noise. I can't watch a DVD on it because it is so loud.  It also gets extremely hot no matter where I lay it.  Any ideas on how to fix?  Thanks
The same happened to me until i changed my laptop to the fan auto learning...now everything is good.
Posted on Dec 11, 2007
You should use the BIOS option for "Fan Auto Learning" and "Battery Power Management", i believe those are the correct names, regardless one option allows the fan to set the RPMs it needs based on temperature. This option works rather well.
Posted on Dec 04, 2007
    Scholar:
  • 155 Answers
I strongly suspect that is the fan. Unfortunately it is necessary to open the laptop and replace it. Try to spray some air on the vent to clean it but I bet it needs to be replaced.
Posted on Oct 20, 2007
SOURCE:
My averatec computer makes a whirring sound
That sounds as if the cooling fan is working very hard. This normally means that the cooling ducts are full of dust and other rubbish. You may be able suck most out with a vacuum cleaner or blast with an air duster. Failing that, it's taking it apart (you will need a manual) to clean the heat sink area around the cpu.
Jun 16, 2014 | Averatec 3200 Notebook
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
Plug got very very hot and now computer only works on battery. I purchased replacement power source which shows is on (green light) but computer still running off battery. I know there is some issue about...
You may have burnt a circuit on the motherboard and now it isn't letting you charge, i wouldn't use it anymore and get the motherboard replaced. ASAP
Oct 24, 2009 | Averatec 3200 Notebook
I have an averatec 3200 laptop.no display
Yes..most probably its HDD. Remove the hrddisk and try booting. If it displays, no HDD.then the prob lies with HDD.
Jun 07, 2009 | Averatec 3200 Notebook
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
My Averatec turns on to the logo screen but keeps resarting
dude heres the deal the blue screen is from a lack of ram simple as that. just add more ram and you shouldn't have that problem anymore. then when the computer starts up reset the page file to double the amount of your ram. that should get rid of the blue screen and you should have a running unit. if this doesn't work then you are best off reinstalling the OS.
Apr 24, 2008 | Averatec 3200 Notebook
My Averatec 3200 has no sound? what do i do?
http://www.averatec.com/customercare/downloads.asp
Select 3200 and then find the part number on the bottom of you laptop.
Download and run the audio file and you should be good to go (it will probably tell you to reboot the computer)
Let me know how this goes, there could be a few more things to try.
Nov 17, 2007 | Averatec 3200 Notebook
Averatec 3200 Laptop turns on for like 2 seconds then shuts off
Im sure the virus would have stopped a boot up unless is was a bios virus which is rare. It's sounds to me as if it's a processor problem, it seems to work at first which suggests the motherboard is working, but then as soon as the pc starts to work hard which is on start up its either getting too hot then shutting down or simply damaged. I assume you cannot get into the bios as it shuts off too quick, but you may still be able to clear the bios by locating the cmos battery and flipping out, as the bios may not be seeing your hard drive and crashing,this will make your laptop pause in the bios first, so trying to get in the bios may be a step forward so as to get the laptop to see your new drive.
Apr 11, 2007 | Averatec 3200 Notebook
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
374 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
