Question about Kenmore Refrigerators
Refrigerator keeps throwing receptacle switch plate
My Kenmore Elite Refrigerator keeps throwing the switch on the receptacle plug. I hit the reset button on the receptacle plate and the refrigerator runs fine for a while, but then it throws the switch again.
    Problem Solver:
  • 8 Answers
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
Posted on May 23, 2009
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Kenmore elite hissing noise and hot rear inner plate
This is normal - it is defrost liquid evaporating.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 20, 2010 | Kenmore Elite 44723SS Commercial...
Kenmore elite refrigerator alarm keeps going off even though the doors are closed
you have to send model number,on some bottom mounts there is a metal striker on the door that hits the switches,sometime that gets bent back,all you have to do is readjust the striker by bending it if screws aren't loose but i don't know what kind of bottom mount you have
Nov 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control pad is flashing and can't seem to reset tempeature
try unplugging the unit and waiting 9 minutes then plugging it back in.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrigerator
i think you will find fan has stopped working - take back plate off inside freezer and check fan goes and that pipework is not iced up
Sep 10, 2008 | Kenmore Refrigerators
Kenmore Elite Trio
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the solution?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
95 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
