Question about Vacuums
I have a DC 18 and the brush will not go around. Pushing the reset button does not help. What is the next step
  • jeangene May 23, 2009
    Yes, I did all of that before I wrote you, but doing it again following your instruction it started to work properly. Thank you.
  • Vacuums Master
  • 13,433 Answers
Have you cleaned the brush? you can open the cover and take it out and clean it, theres a screw you can turn to open the cover.
after you have cleaned it completely make sure you place it back in the same way and then press the reset button.
if its put back together wrong it might not work, so double check that and put it back together.
Is the brush motor getting electricity or is it not properly connected to the main unit?
Brushbar control
The brushbar will re-set to ‘ON’ each time you start the machine and put it in the cleaning position.
To turn the brushbar off, turn the machine on and press the brushbar on/off button.
The brushbar will automatically stop if it becomes obstructed. If the brushbar stops during use,
check for blockages.
Clearing blockages/brushbar
Please note: clearing blockages is not covered by your machine’s limited warranty.
Turn power off and unplug before checking for blockages. Failure to do so could result in electric shock or personal injury.
If any part of your machine becomes blocked, it may overheat and then automatically shut off.
Unplug machine and leave to cool down. Clear blockage before restarting. Please ensure machine is upright before removing hose or airway inspection parts.
Beware of sharp objects when clearing blockages. Refit all parts of the machine
securely before using.
Posted on May 23, 2009
Brushes are not turning on my Dyson 24 vacuum - how can I fix it?
Hi there, it's Jack at Dyson.
DC24's cleaner head is protected by a sensor which shuts the brushbar off if something jams it. To reset your DC24's cleaner head, we would recommend following each of the steps shown in the video below. I appreciate you've already tried the reset button, but it's important to follow all of the steps in the process:
It can help to use something like the eraser-end of a pencil to firmly press the red reset button. You should hear and feel a click as it engages. Please note, the brush bar will never rotate when the machine is standing upright, so make sure you recline it into the normal vacuuming position before testing.
If you'd like additional assistance after giving this a try, you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson guarantee.
Feb 10, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
I just bought a Hoover Air Lite, and the mechanism that moves the belt isn't doing anything, I tried resetting the brushroll but that didn't do anything. Why is it not working and what can I do to fi
Hi Brian! The vacuum must be in vacuum mode for the brushes to spin. Try these trouble shooting steps below to get your brushes spinning.
1. Power the vacuum on.
2. Recline the handle by securing the nozzle and pulling the handle back.
3. Press the brushroll on/off button located directly next to power button.
The brushes should begin to spin, if not repeat the same steps only you will press the brushroll on/off button twice consecutively. This is the brushroll reset procedure. Hope this works out for you!
Oct 02, 2014 | Hoover Vacuums
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
Reset button inoperative
Sounds like 1 of 4 possibilities
1.The button next to your on switch is jammed.
2. The Motor has burnt out within the head unit
3. The PCB Unit is faulty wihin the head unit
4. The thin wires running down the inside of the machine to the head unit hve br
May 23, 2014 | Dyson Dc-18 "slim" Upright Model...
Brush wont turn
The brush may need to be reset via the button next to it. Also remove any hair that may be wrapped around it.
Jun 15, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC 24 brushbar motor stops working , every so often , I press the reset button then it works for a while and stops again till I press reset again.
DC24 is equipped with a safety device which shuts off the brush bar if something jams it - for example, a shoelace or a rug fringe. From what you've described, it sounds like there may be something in the cleaner head which is jamming the brush bar. It's also important to remove any threads or hair from around the brush bar regularly. Please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
You may also find the video below useful. Make sure that before you test the machine, you've reclined it into the vacuuming position, because the brush bar will never rotate when the machine is standing upright.
I'm confident this will resolve the issue, but if you'd like any further assistance, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Nov 25, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
My dyson dc17 turn on but doesn't turn
I am sorry to hear you are having difficulty with your DC17. If the brush bar is not spinning it may be obstructed.
Please visit http://www.dyson.com/support/help.asp?article=956&product=DC17-ANIMAL for step by step instructions on how to inspect your brush bar and clear any obstructions that may be present.
Once you have carried out these steps you may need to reset your brush bar. To do this please plug your machine in, recline it as if you are preparing to vacuum a carpeted surface, turn your machine on and if the brush bar is not spinning push the silver button next to your power button one time. This should reset the brush and it should begin spinning immediately.
If you are still having difficulty with your machine please contact the Dyson US Helpline at 1-866-693-9766 or the Dyson UK Helpline at 0800 298 0298 so we can provide further assistance.
Best wishes,
Jessica
Mar 07, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
