Question about Nikon Coolpix S210 Digital Camera
"memory contains no images"
Nikon coolpix S210 camera. I have 101 pictures on the memory card that was formatted to the camera. I took the pictures out and downloaded them to my computer, put the memory card back in camera and now this is "memory contains no images" comes up and iof I take a picture, it comes on the camera not on memory card. I am very frustrated!!! Please help!
mewms_14904
  • 1027 Answers
SOURCE: card cannot be used
This means that the card memory can not be read, make sure the contacts are, clean. use pressurized air cans available from most places like, Wal-Mart, Best Buy, Staples, etc.
lightly blow out the memory card and the camera slot, check pin alignment, Format the memory card on your computer first and re-insert in camera. Use another card to see if error continues.
Posted on Mar 15, 2008
SOURCE: Memory card data won't show on computer
well im just 12 and all but i herd if you keep you sd memory card in the computer and then shutdown(still with it in the computer) then un plug your pc wait one min plug it back on wait till it loads up the take it out and put it back in it might work hope it helps :)
Posted on Mar 01, 2009
Rammsteins
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
SOURCE: Nikon Coolpix L4 Memory card problem
Original camera had capacity for 249 pix. After formatting camera to free up memory I only have memory for 9 pix
What gives?
Thanks
Posted on Aug 07, 2009
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix S210 lcd broken - need step by step instructions
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Posted on Sep 11, 2009
Testimonial: "Thanks for the suggestions and help. It worked."
How do i delete all the picutes at once on my cool pix s210
You can clear ALL pictures from the card by formatting it. In fact, the memory card should be formatted EVERY time you finish downloading pictures from it. This will prevent later problems.
To format the card in the L20, press MENU, select Setup (the wrench icon), then select "Format card" (the memory card icon).
Jan 13, 2011 | Nikon Coolpix S210 Digital Camera
Can nikon colpix S210 be used for webcam.
You can't. The S210 was designed as a camera, storing high-resolution pictures (and videos) to a memory card. It was not designed to stream low-resolution videos live to another device.
Jun 20, 2010 | Nikon Coolpix S210 Digital Camera
I have taken several pictures with my new camera - when I go to look or print them it says that the "file contains no image data" I took 13 pictures and only 5 show up. Is this a problem with my camera? I...
Make sure you have no pictures on the internal memory of the camera. If you do, format the internal memory with no card in the camera. Then, download any pics you can save from the card to your computer. Then, go into the menu and find "format"...follow the on-screen instructions to erase and optimize the card for the camera.
May 25, 2010 | Nikon Coolpix S4000 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
I cannot download from the S210 onto my laptop
Capture beautiful memories perfectly with a high quality battery for your Nikon Coolpix S210 digital camera. Rechargeable Li-ion 3.7V 660mAh Nikon Coolpix S210 battery for sale,20% Off! Full one year warranty! Website: http://www.nikon-coolpix-replacement-battery.com/coolpix-s210.htm
Jul 26, 2009 | Nikon Coolpix S210 Digital Camera
Pictures not accessible on memory card
Nope. Ur memory card might have been formated by the camera with a different file system.
So use your camera to access your pics and to transfer to PC.
Feb 28, 2009 | Nikon Coolpix S210 Digital Camera
this memory card not formatted error is quite famous, I saw it before, but luckily I found the solution, check it out
Fix Memory card not formatted error and recover files
hope that you can find the help as me.
Jan 30, 2009 | Nikon Coolpix S210 Digital Camera
Out of Memory on Card, but also says: Memory contains no images
I think you may have deleted the folders from your memory card.  The camera could be looking for the folder to put the photo into, and this error comes up instead of one about the folder.
Dec 28, 2008 | Nikon Coolpix S210 Digital Camera
Nikon coolpix 4600
Have you formatted the card? When you buy a new card for a camera it may have to be formatted by the camera so it can be used. Note: Any data on the card will be lost during the formatting, so make sure you have a backup of any content there.
Sep 01, 2006 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
280 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
