Question about Cell Phones
LG KS 360 PC Suite
I installed the Pc suite on my laptop (Windows Vista) it said that the Usb driver was installed but when I want to plug my phone in it keeps saying no phone connected. What can I do
  • 78 Answers
Also install the cable driver from the cd u got with cable.
Posted on May 24, 2009
Whenever i m connecting the cell phone(nokia 3110 c) with the laptop via USB cable the laptop shows me message that DRIVER missing. i want to use the data cable for net connection. pls let me konow from...
Good Day,
For your driver need, you may just install Nokia PC Suite, where it installs the driver and other necessary software, including the software needed for you to use the phone as an internet device.
http://nds1.nokia.com/files/support/global/phones/software/Nokia_Ovi_Suite_webinstaller_ALL.exe
just go to that link, install the software, and you are set. Please do not connect the USB data cable to the PC yet, until the software installation is finished. After all has been installed just plug the USB data cable in the PC and the phone, and follow the instructions on-screen.
Hope this helps you. Thank you for using Fixya.
Aug 09, 2011 | Nokia 3110 Cellular Phone
Where can i find LG KS 360 Pc suite to download
You can download the Lg Pc suite from this link (click here).
If you need further help, let me know.
If it's helpful, don't ignore to Rate.
Good luck
Sep 03, 2010 | LG Cell Phones
Samsung C3060R driver fo Windows 7
uninstall again your pc studio, restart you laptop and reinstall your pc suite, but before you do install it, try to do this trick, right click the pc studio, select properties, then select run in compatability mode of xp and vista, then select run as administrator, select apply and ok. it will install, there are times that windows 7 will inform you that the program not installed, you will be having two options, select, '' install the program with recommended settings''.
once installed, connect your phone to your laptop, select settings on you pc suite, select connections, select usb, this will command the pc suite to search for phones attached to usb ports. once searched, it will install your phone automatically and will look for appropriate device drivers for your phone through your pc suite, once connected you are set.
if this doesn't fix your problem, try updating you device through device manager, direct your device installation by browsing the folder to your samsung pc suite and unchecking the automatically install the best driver and checking the box for include the drivers on this folder.
regards.
Mar 06, 2010 | Cell Phones
Can't view LG KU990's files on my computer
Nah!! i dissagree that solution is way to compicated when you can simply just plug in your USB cord and open the USB driver corresponding to the phone. You do have to have the phone set to Mass storage to do it. {Plug it in and open my computer, the icon will appear by itself, then you'll be able to view and add files and everything else.} No need for any software really.
Mar 16, 2009 | LG KU990 Viewty
LG PC Suite wont connect
try these drivers www.pcleeds.com/drivers.html install the drivers then remove the cable from your phone goto settings connectivity and set you phone from data suite to mass storage then plug your usb back in the phone should now be found as a mass storage device
Mar 08, 2009 | LG KU990 Viewty
How can I setup KC910 Bluetooth modem on my Notebook PC?
Depends what you want to do - if you're just moving files you don't need the PC suite...
Under Connectivity in the Settings screen, set the 'USB Connection Mode' to 'Mass Storage' and then when you plug the phone in to your PC the external drive will appear as another drive as if you'd plugged a USB stick in.
If you really need the Suite (and if you can avoid it: do - it's rubbish) I think you need to go here: http://uk.lgmobile.com and download the support tool, then you probably get the chance to download the PC Suite.
Hope that helps.
Feb 04, 2009 | LG KC910 Renoir Cell Phone
LG KP220 PC SUITE?
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC!  Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3): ----------------------------------
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes     Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes      Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista: -------------------------- When you first connect the phone in COM mode, let vista download the driver from the internet.  Then run PC Sync and viola it'll work!
For both: ------------ For running as a USB flash drive (data mode), you don't need any driver in either o/s. For running as a COM port (phone mode), you need a driver and a software.  The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek.  I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works.  Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
Feb 02, 2009 | LG CU500 Cellular Phone
Lg kc550 drivers for vista?
1) On your phone, go to Menu -> Connectivity -> USB -> And change settings to "Data Service"
2) Plug in your phone to your computer and wait for Device Manager to say "Device has been successfully installed."
3) Go to your LG Phone's Software (PC Suite) and connect.
If PC Suite fails to find a phone,
1) Download another PC Suite at: http://www.fullandfree.info/mobile/lg-ku990-viewty-pc-suite-official-v20115/
2) Double check that your USB Driver is installed.
Nov 12, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Cell Phones Logo
331 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
