Question about HP Computers & Internet
I have an HP mini computer. My monitor screen, when I turn my computer on, has gone from a vertical to horizontal view screen.
  • royrdrgs May 23, 2009
    Your solution did not work.
    Thank you!
  • 10,515 Answers
These are sweet monsters. Any change or even if you play with the default settings, it would harm you :P.
Well,
In order to switch any direction :-
Ctrl + Alt + Up arrow key ( for normal )
You can use downward for different position. Same with sideways.
I hope this would fix the issue. Any further question, let me know.
Thanks for using Fixya.
Do rate the solution as Fixya, if 100% satisfied.
Posted on May 23, 2009
  • taran_2005
    taran_2005 May 23, 2009
    It's Impossible that the above solution would not work.
    Make sure you need to press
    Ctrl Alt Arrow key( Upward One ) together.
    I have never seen a notebook whose display has been shifted not being cured by this.
    If unable to follow the steps, format the notebook. This would bring the notebook to its default stage or go for system restore.
    Thanks.
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
We have a Hewlett Packard F1703 monitor...... Our cat sat on the keyboard and the monitor screen went from a horizontal view to a vertical one. We have to turn the monitor on it's side to view it. We have...
Press CTRL + ALT + Down Arrow Key It will Work if Not then Righ Click on Desktop Screen -> Graphic Properties -> Hot Keys ->Uncheck or Check the option it would be done
May 30, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a hp monitor that can change from horizontal to vertical but when i turn it it doesnt change screen postion. how do i fix this
If you go to the HP support website (hp.com/support) you can download the application for your monitor that automatically switches the resolution and orientation upon swiveling the monitor form horizontal to vertical or vice versa.
Feb 06, 2010 | HP Computers & Internet
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
My problem is about our lcd monitor, at first it has this vertical black color between 2 sides and i like it because it does not affect the horizontal view in my games,,but now, the black in the 2 sides...
I think your screen is set up for "widescreen".
This is also called 16:9.
I would browse the monitor's menu (where you adjust the brightness and contrast', and see if you can put it back to 4:3 (4:3 is the ratio of a TV, kinda square").
I suggest that you try that, and post back with your monitor's model. (example : Samsung T220). It should be written on the monitor.
Jan 11, 2009 | Computers & Internet
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Monitor viewing position
what model of monitor do you have..?
May 18, 2008 | Philips Brilliance 107B 17" CRT Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
