Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
FM tuner sound fluctuates when car is moving
HI, i am facing a problem with fm tuner, the mp3 is working fine.... the problem is when the car is stationary the fm sound is crystal clear....as soon as i accelerate and the car moves the fm sound goes up and down(fluctuates). This does not happen with the mp3 sound. kindly help.
  • 108 Answers
SOURCE: no sound
you simply have a speaker shorting in your car. Either an old speaker with a bad voice coil (short) or a speaker who's contact(s) are touching metal. This type of short or grounding will cause the internal audio amplifier to shut off to protect the radio's output circuit. To diagnose which speaker is the culprit, you'll need to disconnect all speaker leads from the radio and one by one re-connect them until the output shuts down again. The safe way to check is with a voltmeter. If you connect one side of your voltmeter to ground and test each speaker wire lead for continuity, you'll hear an audible "beep" whe you find the grounded wire/contact. A professional car audio shop can diagnose this for you if you're still having difficulty. Hope this information was helpful.
Posted on Sep 28, 2008
  • 124 Answers
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Posted on Dec 27, 2008
  • 341 Answers
SOURCE: I have a DEH-P7900BT. It was working very well for
I would check both of the power wires for the unit. There is a yellow one and a red one. The yellow one always has power regardless of the position of the ignition switch. The red one only gets power when the ignition switch is in the on position. Also does this only happen when the vehicle is in motion or does it happen just sitting and listening to the stereo? It also could possibly be the ground wire not getting a good connection. Make sure the ground wire is tightly connected to something that is metal. Good luck.
Posted on Jul 18, 2009
raklein62
  • 360 Answers
SOURCE: There is no sound comming from My deh-27mp (on
Sounds like you blew both channels out. It is possible that you have a battery problem, and not sourcing enough voltage or current to operate the device. If service Tech say's he can't find nothing wrong then recheck your battery connection, and have Auto Zone check your alternator. Hope this helps!
Posted on Oct 21, 2009
  • 8 Answers
SOURCE: HOW DO YOU SET THE
See instructions below:
Initial Settings
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press FUNCTION and hold until function
name appears in the display.
3 Press FUNCTION repeatedly to switch
between the following settings:
CALENDAR (date and clock)—
WARNING TONE (warning tone)—AUX1 (auxiliary
input1)—AUX2 (auxiliary input2)—
DIMMER (dimmer)—S/W CONTROL (rear
output and subwoofer controller)—
DEMONSTRATION (feature demo)—
EVER-SCROLL (ever scroll)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down FUNCTION until the unit turns off.
Setting the date and clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment you
wish to set.
Day—Month—Year—Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Press a or b to set the date and clock.
Pressing a will increase the value of the selected
segment. Pressing b will decrease the
value of the selected segment.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/415128381DEHP4900IBOperationManual0216.pdf
Posted on Aug 20, 2010
FM radio does not work on receiver
Unfortunatly it sounds like the FM tuner pack is faulty and only replacement can cure it.
Jan 12, 2013 | Car Audio & Video
The am/fm doesn't work but when i plug in my mp3 its fine, any tips on fixing this.
The AM/FM tuner has been damaged. Ask Dewalt support if they can repair it. If the unit is under warranty, have it replaced.
Aug 25, 2011 | Dewalt DC011 AM/FM Radio
Hi, I have installed my JVC radio and when it is on FM radio, there is sound through the speakers, but when I play a cd there is no sound.
are you using an amplifier? if so, it sounds like you are using the blue wire (power antenna remote) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. when leaving tuner mode the power antenna wire is turned off.
Feb 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
Cannot get any sound from fm. i have stations and aerial is ok just have sound on mw/lw any suggestions? gail
seems the fm tuner is blown, did you check antenna and connections? if ok then contact service for fm tuner problem.
regards
Feb 19, 2011 | JC Whitney SONY XPLOD 10-DISC CD/MP3...
I CAN NOT GET FM RADIO ON MY KA STEREO, CD PLAYER IS FINE AND CAN GET LW. PLEASE HELP!!!!!
FM tuner module may be faulty and need replacing. It may simply be dry joints on the tuner which will come good if you resolder the dry joints.
Oct 09, 2009 | JVC AM FM CD DET FACE CAR STEREO
FM Radio
Hi
iPods do not come with FM tuners. FM tuners can be bought and added on as an extra feature, but this is a third party device, not an iPod device.
Generally, when you connect the third party FM tuner to the iPod, the iPod will recognize it and you can use the 3rd party FM tuner to change stations.
If you do not have the FM tuner to connect to the iPod, the individual that sold you the iPod did not include the FM tuner to connect to the the iPod. In that case, the Menu will still list the FM tuner, but there is no device to connect to the iPod.
Sep 09, 2008 | Apple iPod MA446LL/A MP3 Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
FM Tuner not working.
has the unit been dropped?
the antenna is the ear phones so other than that it looks like the units fm tuner is bad.
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Car kit/ FM tuner for playback?
well, depending where you are, there are stores that sell fm tuners for about 30 $. These fm tuners are universal. They just plug in the earphone jack and you tune to 88.1 mhz. It works with batteries or even the ones made for cars, you plug it in the cigarette jack. So go see at radio shack or best buy. They have for sure, im in canada and well they have like 4 diferrent models ! Be sure to ask someone there, its easier that way !
Jun 29, 2007 | iLO (2 GB) MP3 Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
82 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
