Question about Uniden BCD996T Base Scanner
I just ptohtsmrf mu uniden bcd996t base scanner with only one trunking system and erased all the others that came with it. problem is when it is working in the trunking area on this single trunking system it seems to forget what it was doing and it starts searching and if left on its own it hangs up on some local FM radio station. when I go back it is hard to get it started working in the trunking section that I set up. I have to hunt for it and the quick key "1" dont automatically take it to that system (which is the only one on the scanner)
  • 1 more comment
  • hogue490 May 23, 2009
    I only have one trunking system programed into my bcd996t trunk tracker. it works fine for a few hours or less then an hour then it starts searching for a strong signal and winds up lockint into a FM radio station signal.
    Why does it go into search mode after a short period.
    I just purchased my uniden bcd996t base scanner with only one trunking system and erased all the others that came with it. problem is when it is working in the trunking area on this single trunking system it seems to forget what it was doing and it starts searching and if left on its own it hangs up on some local FM radio station. when I go back it is hard to get it started working in the trunking section that I set up. I have to hunt for it and the quick key "1" dont automatically take it to that system (which is the only one on the scanner)Comment posted on May 23, 2009
    Why does it go into search mode after a short period.....
    Also I searched the manual and the FAQa on Uniden without any solution.
    I just reset the system: erased all systems and installed a fresh copy of the new trunking system; I am letting it run now to see if it goes into search. I hope this is the end of it. but I will have to wait and see as the first time took about about 3 hours when the trunking data channel changed, it started searcing right after that. I am not sure if that had anything to do with it or not.
    I will keep you posted.
  • 749 Answers
Try to reset the scanner unplug it for 30 mins and try again.
Posted on May 23, 2009
    Sergeant:
  • 187 Answers
try this link
http://www.uniden.com/index/manuals_results.cfm?cat=3
please rate my suggestion...
    Brigadier General:
  • 3,614 Answers
This is only used to monitor a special computerized "trunked" radio system. Agencies that are using a Trunked system have a central computer that "handles" multiple frequencies (channels) & Transmitters, putting various & multiple different system users/groups on a vacant frequency(s) as needed. A user/group could theoretically be on a different "channel" every time they key the microphone. This multiple frequency "jumping", & multiple different user groups on the same channels makes it hard or impossible to "follow" conversations or realize what group is talking, when using a non-trunktracking scanner. However, If the signals & channels you monitor are not part of any "Trunked" Radio system, then the scanner's Trunking features would not, & cannot be used for them, & gives no additional benifit when monitoring your "regular" channels.
I need to delete one frequency at a time from a uniden BCD996T scanner.
it scan run all nuber threw all exct there 3 numbers wont scan it like there stuck they wont move at all then weather radio come on and it turend off
t
Feb 24, 2014 | Uniden BCD996T Base Scanner
No clue how to program the scanner !!
Your best choice for software is the BuTel program. You can find it on Butel.com, ScannerWorld.com, or RadioReference.com. Once you have it installed you can download and program both conventional and trunked systems directly from RadioReference.com. I have the BCD996XT with Butel and RadioReference, and the combination works great.
Bill B
Apr 20, 2010 | Uniden BCD996T Base Scanner
Trunking no longer works on my BCD996T scanner, Conventional work
Hi Mike,
Try updating the firmware and see if this solves the problem. While I understand that it "worked before", some of the programming software has been updated to work only with the newer firmware. Also, the newer versions of programming software are required when importing systems directly from radio database sites (such as radioreference.com).
If this does not work, try to enter system data by hand rather than importing. If trunking works then, it sounds like a software problem with your programming software versus the radio itself.
Hope this helps!
Feb 13, 2010 | Uniden BCD996T Base Scanner
Unable to program trunking after uniden download was completed
I would try redownloading and reflashing the firmware on the scanner. If this doesn't work, you may want to try downgrading to the previous version of the firmware. If you are unable to redownload the firmware from Uniden, there is a Yahoogroup dedicated to this radio.
http://groups.yahoo.com/group/BCD996T/join
Also in the files section, there are older versions of the firmware.
Hope this helps!
Feb 10, 2010 | Uniden BCD996T Base Scanner
How do i program a uniden truncktracker
Sorry, but there is absolutely no way to cover programming of such a sophisticated scanner in this forum. If you need the manual for reference you can download/print by following the link below. Your best bet, outside of the manual, is to join a scanner group in your area, or purchase scanning software such as the ARC996 from BuTel (http://www.butel.nl/) and download/program using the services of RadioReference.com. RadioReference is also the best source for active frequencies and trunking systems in your area.
http://www.uniden.com/pdf/BCD996Tom.pdf
Dec 28, 2009 | Uniden BCD996T Base Scanner
Uniden BCD996t
I went through the manual page by page and found no info on how to doa complete system reset.You might join the BCD996T Yahoo user group and ask your question there or look through this easier to use guide I found on the internet.(http://marksscanners.com/996/996.html)
May 07, 2008 | Uniden BCD996T Base Scanner
Uniden bcd996t
Hello wfd88,
You need a copy of Uniden Advanced Scanner Director software. You can download the software from http://www.uniden.com in the Customer Service Downloads link.
Also, as a reminder, you need to use the cable supplied with the scanner and, if I recall correctly has a Uniden custom connector on one end and a serial connector on the other. If you do not have such a cable, Uniden sells a USB to Serial converter under the model USB-1.
If, during transfer, you get an error message, reduce the scanner’s serial port speed setting and start again until you get reliable, complete transfer of data.
Let me know if this helps.
cancerags
Dec 28, 2007 | Uniden BCD996T Base Scanner
1.2.3.Guide
Try this link: http://myweb.cableone.net/marksscanners/996/996.html
The scanner memory is different than others in the way that it is organized. But the basic syntax is: SYSTEM/GROUP/CHANNEL.
Don't give up. It's a great little scanner.
Sep 07, 2007 | Uniden BCD996T Base Scanner
Uniden BCD996T Base Scanner Logo
87 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
