Question about Canon Cameras
Water inside the lens (Canon EF-S 17-85mm F4.5-f5.6 lens)
I have got water inside my EOS 17-85 mm IS lens and need to dismantle it to clean the inner lens elements.
  • 130 Answers
If it is only fogged you can blow hot air on the lens while fully zoomed in and after the water has evaporated, zoom out to compress the moist air out. do this several times.
Posted on Jun 13, 2009
Canon 50 mm 1.8 communication error 01 lens malfunctiion
Might be that the aperture is stuck and you need to get the lens repaired (might cost more than a new lens.) Or it might just be bad contacts. Clean the contacts and try another lens before asking Canon or dismantling the lens.
Aug 30, 2013 | Canon EF 50mm f/1.8 II Lens
Canon EF-S 18-55mm f/3.5-5.6 USN Lens won`t auto focus
Try cleaning the electronic contacts on the lens and camera.
Jun 30, 2017 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Hi I have used my canon camera eos 400d with the 17-85 mm canon lense for nearly 2 years. Since last week i am encouttering the error 99 < replace the battery and try again>.I did this...
The lens most probably has dirty contact between the lens and camera body. It only worked with the "default" lens because you disturbed the dirt removing the 17-85 lens.
Here is what I'm suggesting, seeing you said the problem was solved by changing out the lens.
Clean the contact both on the lens and camera body with a pencil eraser, hold the camera body so the lens cavity is pointed downward and lightly polish the contacts don't use a puffer to clean the area you will just blow dirt into the camera.
Do the same with the lens contacts and you will be good to go
Mar 30, 2011 | Canon EOS 40D Digital Camera with 17-85mm...
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Error 99 appears using 17-85 lens only when some zoom is being used
Can you replicate this fault on other lenses? Is it is only on the 17-85 lens try cleaning the lens contacts with a pencil eraser and see if it helps.
Nov 03, 2010 | Canon EOS 30D / EF-S 17-85mm IS Digital...
If I buy a Canon EOS 500D body wil my 500n AF lens fit it and operate OK?
All canon EF and EF-S lenses work with 500D /T1i model.(yes all)
If your lens is removed from old 500N body and if it has EF marked it will work for every Digital camera model of canon.
Note: its focal length will be multiplied by 1.6 X factor.
(mean 18 mm lens will become 29mm approx.)
If you find this of help rate me.
Nov 23, 2009 | Canon EOS 500D / Digital Rebel T1i Body...
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
Friction in zoom, Sigma AF 70-300mm for Canon-EOS
Its more like a distorted inner zoom barrel or sand and dirt inside  the inner barrel will need to be replaced or you need to dismantle and clean out
Nov 09, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Cameras Logo
998 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
