Question about Yamaha Audio Players & Recorders
RX-V2500 stays in protect mode
Unit has preformed perfectly for two years. Has been attached to a Bose acoustimass 600 system the entire time. This week unit has started to instantly go into protect mode. Have done all the manul trouble shooting. Unit currently has all wires removed and only the electric cable attached, still clicks to protect mode. Help!!!
  • margmacc May 23, 2009
    Ok, pulled the cover off and besides a very light cover of dust (2 years) she looks pretty pristine in there. Did not see any globs of glue or other sticky matter. Just a blue million electrical parts and componants.
  • 586 Answers
    The set i in protection due to power supply. Some comonents being short (malfunction). It require proper checkup because in protection mode, Many components are involvd and protection is commanded by the processing IC (Main chip IC), If some where in the power or other sections any component creat problem processing IC take quick action to avoide further damages, that's why set goes in protection mode. I suggest you to check physically and most probebly capacitors must be blown or dehaped or popped. If you seen such things then change it therwise contact any expert because it is time taken procedure to find out which component is not working. Therefore contact any expert nearby to avoide any further damadges.
Thanks for using fixya.
Posted on May 23, 2009
    President:
  • 987 Answers
I just wanted to share my experience repairing my Yamaha M-60 power amp. After twenty years of use, the protection circuit wouldn't shut off. I did what the owner's manual said to do ... check speakers and cycle power. That didn't work, so it was time to either junk it or roll my sleeves up and go to work.
After removing the cover and blowing out the dust, I found a significant amount of old yellowish adhesive globbed under some components. The stuff was looking a little crusty and was covering the leads on some of the circuit board components.
I carefully removed as much of the old glue as I could and found that one of the leads on a diode was completely loose, Probably due to corrosion caused by the old yellow glue. Fortunately there was enough lead left to be resoldered back into place. So I gave it a try.
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Better sound through bose speakers?
If you have the money to plunk down for a Bose Acoustimass home theater speaker system, I'm sure you will be quite pleased. Of course, as you indicated, appropriate placement of the speakers is important. Still, I'm sure you will find that a properly placed Bose Acoustimass speaker system will fill your room with high quality sound, substantially better than Onkyo's stock speakers placed equally well.
I own a Technics home theater system, which I initially purchased to use in my family room. Yet, when I listened to a Bose Lifestyle system (powered by Bose Acoustimass speakers), I could have nothing less. The Bose system went in the family room, where everyone could enjoy it. I put the Technics system in the bedroom, where it is rarely used.
Jan 09, 2010 | Onkyo HTR500 Receiver
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
I have a bose Lifestyle Series II System which i have enjoyed for years. My son recently tried to hook his I-Pod to it. now i cannot get it to work. Any ideas?
Hi.
The system may have gone on protect mode after detecting a problem.
Try disconnecting the power cord from both subwoofer/amp (Acoustimass), and from main control unit.
While the two units are disconnected, check the control cable from main unit to subvoofer, and check all the speakers connections.
Leave system disconnected for about fifteen minutes, then connect back first control cable, then power to Acoustimass (keep it off) and finally, power to control unit. Turn everything on and see if the system is starting.
If the system is still not starting, then there is an internal fault. In that case call Bose at the number listed on the owners manual.
Regards.
Dec 20, 2009 | Bose Audio Players & Recorders
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
BOSE ACOUSTIMASS SYSTEM 15 SUBWOOFER - NO POWER
I will try as best I can... There is no light on the unit. There is a two position switch, that's your on/off switch located on the botttom of the unit next to the pwr cord input... When the straight lined side is pushed down the unit is energized. When you pwr up the unit you should hear a light bump, not a cracking noise. There is a fuse on the main input/output board that is pretty easy to pop and swap.
Jan 17, 2009 | Bose Acoustimass 15 System
Onkyo HT-R520 Immediatly goes to standby mode when turned on
This Yamaha model has a "Thermal Protection Integrated Circuit", You can check the online manual at www.yamaha-uk/pdf/owner_manuals/rx-v2500.pdf
May 17, 2008 | Yamaha RX-V2500 Receiver
AM15 LFE (BASS) MODULE NOT WORKING AFTER ONE YEAR
I have the same problem too, I have replaced the fuse that blow inside, but did not work it just blow again and again call bose and they told me that may be the amplifier that when off.
Dec 21, 2007 | Bose Acoustimass 16 System
111 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
