Question about Refrigerators
Our fridge stopped cooling-the gas is leaking-any danger to us
Our fridge is working but not cooling at all- a mechanic said that the gas is leaking- is it any danger to us? - the new fridge is coming in 2-days. If we unplug the fridge -will the gas stop leaking? Leone.I have a chemical or turpentine type odor in my kitchen. Could it be coming from the refrigrator? Or is because I spilled some cleaning products the other day. I cleaned up the floor so the cleaning products should not still be there. What do you think?
    Brigadier General:
  • Refrigerators Master
  • 3,614 Answers
Better to remove the unit when your new unit has arrived, your repairman is right the gas coming from the fridge is very danger for your family to be inhaled even you unplug the unit,
Posted on May 23, 2009
Have a frigorex coca cola fridge in my shop, at the moment it is not cooling stock, what are the usual problems with this fridge
fridges not cooling regardless of make suffer from several problems.
low gas from a leak door not closing properly/leaking door seals
compressor motor not running from low gas /overload/burnt out
faulty thermostat /settings. In a business because you need the unit to operate all the time ,get a fridge mechanic in to fix it
Dec 23, 2014 | Refrigerators
My Norcold model 663. Is not switching to AC.
When gas is leaking, first fridge will stop working, than the freezer. I hope you dont have gas leaking. Is the compressor running all the time?
Dec 03, 2017 | Refrigerators
Bad smell from fridge (not mouldy food)?
There is no danger if there is a leak, but the refrigerator will quit cooling. I suspect perhaps you have a dead something underneath or behind the refrigerator. I hope this helps... but I also suspect you have cleared the problem by now.
Mar 25, 2014 | Freezers
Have dometic fridge RM2553. Has been going great. Yesterday showed on red at dial BUT when checked vent it was hot; so going but not showing in green. Safe?I live in my Jayco caravan so this recent problem...
Hi.
The safety mechanism will still be working. The only case it won't be working is when the safety mechanism itself is causing the problem. In that case there will be no risk because flame will be forced to turn off.
The indicator on red is telling you that the fridge is not cooling. It does not affect the safety of your Dometic.
The safety mechanism in your Dometic works using a thermocouple and a safety valve. When either of this will fail the gas flame will turn off, and the fridge will stop cooling. The safety mechanism works even when it is broken, as it does not allow gas valve opening.
About poor cooling, there are a number of reason that may result in insufficient cooling with this kind of fridge.
Check if there is flame, if there is no flame, then testing will start from igniter, coil, flame sensor and safety valve.
Ensure that there is enough ventilation.Thermostat and cooling unit must be tested if flame operations are OK.
On LP gas, check filter. Check pressure regulator and gas from the lines.
I have included a link to the service manual. Please click below to open the file in PDF format:
Service manual.
Regards.
Ginko.
Mar 23, 2011 | Refrigerators
My fridge has stop working, it will not freeze nor cool, the fan and compressor is working, help
No gas. Please keep your arm in side of the fridge door or discharge line. If you feel little above normal heat, there is gas. Otherwise check for leak testing and rectify. Call repairman.
Jan 22, 2011 | Whirlpool GD2SHGX Refrigerator
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
REGRIGERATOR IS NOT COOLING
It sounds like your refrigerant is leaking out. Without proper test gear you can't confirm this, but the first thing that happens is it stops cooling.
You need to call out a qualified refrigeration engineer to check it. You may be able to see oil at the back of the fridge around the leaking joint. Do not leave it switched on and running if you have a leak. Have you smelt anything unusual recently? The gas isn't dangerous in the quantities you would have from a leak unless it is exposed to a naked flame. Then it breaks down into a gas similar to mustard gas which was used during the first world war. If you didn't notice the smell of the refrigerant gas, you won't miss it if it is around a naked flame.
Aug 15, 2009 | Maytag MZD2669KE Side by Side Refrigerator
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
NO ITS NOT A DANGER TO YOU FREON HAS NO HARMFUL GASES
Apr 30, 2009 | Refrigerators
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
