Question about Certance (CL1001-R) Ultrium Tape Drive
Windows server 2000 does not see back up drive
At boot up the drive comes up in the BIOS screen but not in widows  Any Help   Please    E mail Address lee@theclcgroup.com
Thanks   Lee
    Novelist:
    Champion:
  • 244 Answers
Change your CMOS settings with the boot sequence. You can find an option first boot: change it to cdrom; second boot: harddisk and etc.
rate me solve please
Posted on Nov 20, 2007
Sss i forgot my email and password
Don't know about your email but if its a Windows password you have lost go here http://pogostick.net/~pnh/ntpasswd/ and download the "Windows Change Password / Registry Editor / Boot CD" from the link Password reset CD/USB bootdisk: Instructions & image to download.
NOTES
"The password reset and registry edit has now been tested with the following:
NT 3.51, NT 4, Windows 2000, Windows XP, Windows 2003 Server,
Vista, Windows 7 and Server 2008.
As far as I know, it will work with all Service Packs (SP) and
all editions (Professional, Server, Home etc)
Also, 64 bit windows version (XP, 2003, Vista, 2008, Win7) shold be OK.
To make a bootable USB drive / key:
1. Copy all files from this CD onto the USB drive.
It cannot be in a subdirectory on the drive.
You do not need delete files already on the drive.
2. Install the bootloader (you may have to be administrator)
On the USB drive, there should now be a file "syslinux.exe".
Run this from a command line, like this:
j:syslinux.exe -ma j:
replace j with some other letter if your USB drive is on another
drive letter than j:
On some drives, you may have to omit the -ma option if you
get an error.
If it says nothing, it probably did install the bootloader.
Please note that you may have to adjust settings in your computers BIOS
setup to boot from USB.
Also, some BIOS (often older machines) simply won't boot from USB anyway.
Unfortunately, there are extremely many different versions of BIOS,
and a lot of them are rather buggy when it comes to booting off different
media, so I am unable to help you."
Feb 01, 2014 | HP Compaq Presario V2000 Notebook
Hello I have a query guys on hp ML350 server is that at the end of the inauguration of Windows blue screen appears You change the RAM first and then reduce Alhardat from three to two, but without the...
The system is not designed to use IDE hard drives which why you are getting a blue screen. It is designed to use SCSI hard drives and IDE CD/DVD drives. It might be possible to go into the server's BIOS setup and change the boot device from the onboard SCSI controller to the IDE controller. It is very likely that you will have to disconnect all SCSI devices to boot to IDE, if it is possible.
I hope this helps.
Nov 27, 2012 | HP Compaq ProLiant ML350 G3 Server
Install linux
Did you save it to cmos before restarting your computer ? F10
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Oct 26, 2012 | Intel Dell Poweredge 860 Server 1-socket...
I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
HI I Trying to restore my ASUS EEE PC 900. It has no CD drive. I tried doing the F9 option but it does not seem to work. It keeps bringing me to the black screen where it says safe mode, start windows...
Method 1 :
  Installed Operating system with an external usb CD or DVD Rom drive.Set your laptop to boot from USB CD ROM in your BIOS.
Method 2 :
  Yoou need an PC with windows server 2000/2003 with RIS (Remote Installation server Set up plus DHCP (Dynamic Host configuration protocol) server ).Change your laptop BIOS Boot setting to boot from Network and installed as if you are installing through  normal procedure.
For more information on setting up RIS Server and DHCP.
here is the link
http://support.microsoft.com/kb/298750
http://www.windowsnetworking.com/articles_tutorials/Setting-Up-DHCP-Server-Organization.html
Dec 20, 2009 | ASUS Eee PC 900 Notebook
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
Dec 05, 2008 | Computers & Internet
My Tecra 8100 will no longer boot
GO I2 THE BIOS SET UP DEFAULTS ,SAVE AND EXIT ,IT SHOUL DBOOT OFF THE CD DRIVE THEN H/DRIVE DEPENDS HOW YOUVE GOT IT CONFIGERD
Oct 28, 2008 | Toshiba Tecra 8100 Notebook
Net Framework Error
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
375
Jul 19, 2008 | Microsoft Windows 2000 for PC
Server 2000
Hey karl12,  i think some more info would be helpful.  Any big event that made this start.  Have you tried running memtest 86?  If you have multiple sticks of RAM try each one.  Is there any beeping during boot up?  Have you tried using a windows disc to boot to a repair console?  Also what are your bios settings?  Have you tried changing to load safe defaults in your bios?  Is your bios recognizing your boot hard drive?  These should help limit the possibilities.
Oct 16, 2007 | HP Compaq Evo w4000 PC Desktop
Certance (CL1001-R) Ultrium Tape Drive Logo
97 people viewed this question
Top Certance Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Certance Computer and Internet Expert? Answer questions, earn points and help others
